Travis Posted March 10, 2010 Report Share Posted March 10, 2010 There was a question in another thread about printing patterns. It occurred to me that there are lots of different ways to print the patterns provided here on SSV. For a new scroller, it's not very obvious how to use these great patterns. I'd like to get a bunch of different ways others use the patterns on SSV. So, h'bout it? How do you prepare/print your patterns? I personally use Inkscape to scale and print patterns. Quote Link to comment Share on other sites More sharing options...
panhandler Posted March 10, 2010 Report Share Posted March 10, 2010 So far I have had good luck just using Gimp to resize and print. Quote Link to comment Share on other sites More sharing options...
merlin Posted March 10, 2010 Report Share Posted March 10, 2010 I just use the printer options. First I "Save Image As' then go to where I saved it, double click the image/pattern, that takes me to Windows Photo Gallery, I then click CTRL-P to access the printer options, from there it's a matter of choosing what size etc, etc, etc. Hope that is of help. Merlin OCtoolguy and amazingkevin 1 1 Quote Link to comment Share on other sites More sharing options...
Dave M Posted March 11, 2010 Report Share Posted March 11, 2010 After downloading to a scroll file on my computer I open Picasa, a free photo program from Google. When I print from here they give me multiple size options for printing purposes, I don't ever resize as long as the size works for my project. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
qlty Posted March 11, 2010 Report Share Posted March 11, 2010 I have a hp printer that lets me chose print quality and have found that useing {fast draft} and[ black ink only] is good enough for a pattern in most cases.The printer prints really fast and saves ink. Jim Finn and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
Gypsum Posted March 12, 2010 Report Share Posted March 12, 2010 Patterns that fit on regular paper I just print (I usually change the color from black to red which seems easier to see). Patterns where the cutting will be larger than the standard 8 1/2" X 11" paper stock I take to Office Depot. I print the pattern on regular paper, decide what the size of the cutting will be by measuring the largest dimension (length or width). If the longest dimension is 7 1/2" and I want that to be 12" (11" X 14" frame, 1" border), the pattern needs to be enlarged by 160% (use a proportional scale from an art supply store). The cost for B&W is less than $1 here. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
m_r_dxn Posted March 12, 2010 Report Share Posted March 12, 2010 I usually upload into Corel. I usually do a quicktrace to "vectorize" the image, then change the pattern to the 20%gray with red outline, then resize if needed. Then, I either print, or publish to pdf for later printing. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Papatch Posted September 5, 2012 Report Share Posted September 5, 2012 For downloaded patterns I rework them a little using GIMP (Thanks to Travis), export to the desktop and import into InkScape to scale and size the drawing to the size I prefer, 8.5 x 11 or 11 x 17. If I want larger I use the Poster utility in my HP tools. I use InkScape to change the color form black to light grey with a thin black outline, this is easy on my eyes and save a lot of ink. The poster utility will create a drawing that is either 4, 9, 16 or 25 times as large as the 8.5 x 11 original. You simply print it out and tape the pages together. If you want something a bit smaller you'll need to scale the size down using either InkScape or Gimp, you would still print it on 8.5x11 sheets of paper, you would have some trimming to do before you tape them together. If your printer has this utility it can save you a trip to the print shop. Ed Sr. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Docupton Posted September 5, 2012 Report Share Posted September 5, 2012 I right click on the chosen pattern, save to a folder (documents or picture folder) and print directly from there. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Clayton717 Posted September 6, 2012 Report Share Posted September 6, 2012 I save the pattern to my computer. The open it with paint shop, with this I can resize it and print. OCtoolguy and Jim Finn 2 Quote Link to comment Share on other sites More sharing options...
Jim Finn Posted September 7, 2012 Report Share Posted September 7, 2012 I save to "Paint" and edit, resize and print from there. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
harleyguy Posted September 8, 2012 Report Share Posted September 8, 2012 It is easy to do in microsoft paint. Check it out. I agree with Jim Finn. OCtoolguy and Jim Finn 2 Quote Link to comment Share on other sites More sharing options...
kcortese Posted September 10, 2012 Report Share Posted September 10, 2012 I create, scan and then save the pattern on my computer (.jpeg). I then open it up in Unlead Photo Express where I resize, change the color of the pattern. I print out in blue because for me, it seems easy to see when scrolling, red works well too. I print the pattern out on light weight see through parchment paper. I tape the thin parchement paper to a thicker piece of paper when sending it through the printer. I use rubber cement to glue to the wood. Rubber cement makes it easy to remove pattern and glue after scrolling, and will not soak into the wood to seal it. When I need to print a very large pattern, I use MS Publisher. The image will print on several sheets, cut and tape back together. Having fun with it. So far, this has process worked out for me. But then, I new at this. Karen Quote Link to comment Share on other sites More sharing options...
BanD1t6 Posted September 24, 2012 Report Share Posted September 24, 2012 I work patterns thru either photoshop or PSPro,save as .jpeg. Then i use a program called "Rasterbater" to scale them out. Free program. makes PDF file to print. Quote Link to comment Share on other sites More sharing options...
PawPawRay Posted September 24, 2012 Report Share Posted September 24, 2012 I use photoshop elements Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted October 18, 2013 Report Share Posted October 18, 2013 I CLICK ON RAPID RESIZER CHOSE THE SIZES I WANT AND PRINT Quote Link to comment Share on other sites More sharing options...
vykus Posted November 23, 2013 Report Share Posted November 23, 2013 I do most of my work in an old version of Photoshop CS then change to a vector in inkscape and change it to grey with a black outline. I save that as a png. I then go to a free program called PosteRazor to resize to literally any dimension I want. It then saves it as a PDF. just print that out, tape them together and I'm good to go. Quote Link to comment Share on other sites More sharing options...
tvman44 Posted November 23, 2013 Report Share Posted November 23, 2013 I like Inkscape! Quote Link to comment Share on other sites More sharing options...
browders Posted November 23, 2013 Report Share Posted November 23, 2013 I use Inkscape to size the pattern. I save it as a PDF and print it from Adobe. So far so good. Quote Link to comment Share on other sites More sharing options...
Sparkey Posted November 24, 2013 Report Share Posted November 24, 2013 I tried to print but it comes out too small. I tried to make it larger in paint, gimp and inkscape with no luck. I tried everything in the help menu and nothing worked. Quote Link to comment Share on other sites More sharing options...
HoosierWood Posted November 27, 2013 Report Share Posted November 27, 2013 I do most of my work in an old version of Photoshop CS then change to a vector in inkscape and change it to grey with a black outline. I save that as a png. I then go to a free program called PosteRazor to resize to literally any dimension I want. It then saves it as a PDF. just print that out, tape them together and I'm good to go. Downloaded PosteRazor and it made things a lot easier. Thank you for the suggestion. vykus 1 Quote Link to comment Share on other sites More sharing options...
