So excited for Corian
Casey Jourdan
I've seen other folks cut Corian (the epoxy counter top material) and I've wanted to try but never got around to buying any. Turns out a friend of mine and her husband run a counter top business! He asked if I wanted some scraps so I of course scooped it up. Just cut a quick Steve Good ornament to try it out. I'm in love!  :smitten:  :smitten:
Very nicely done Casey.  One thing about corian is that it can be a pain to finish IF all you are doing is sanding it.  You can sand it up to about 5,000 or 6,000 grit and get a nearly perfectly smooth finish or you can sand to something like 800 grit and use a lacquer and get something that works as well.  Lof the Christmas tree btw.
DW
DW
Thanks for the heads up. I do a fair amount with regular epoxy resin and it's a pain too. I usually to sand that stuff to about 1200 then lacquer. Gonna try the same.
It smells so good cutting,and that's the bad part !I like your cutting!!!
Edited by amazingkevin
I learned a lot from this post and I am going to try to find a place to buy some of it and give it a try. I love posts like this one about something unusual that is cut, either a new idea for a pattern or a material that most do not cut
Dick
heppnerguy
Love hearing this! Hope you find some and enjoy.
