Gordster Posted February 18, 2017 Report Share Posted February 18, 2017 A fellow asked me go make him a sign for his gate entitled Do Drop In.This is what I put together. It is 3/4 inch pine stained with dark walnut. Then given 3 coats of spar varnish. The letters I use just paint.I do not put spar on the white letters as they will turn yellow. The letters and horses are raised by tilting the saw table to the left.Cut Counterclockwise. I usually tilt the table around 7 degrees, but because of so many letters here I only went 5 degrees.The centers in the letters O and D, I cut clockwise which will recess that part back.These are fun to make and the raised letters set it off nicely. Lucky2, Falcon, 125 CSL and 6 others 9 Quote Link to comment Share on other sites More sharing options...
Rob Posted February 18, 2017 Report Share Posted February 18, 2017 It's hard to see the raised effect from the photo but that is a very nice sign. I bet it looks even better in real life where you can see the raised effect. Rob Gordster 1 Quote Link to comment Share on other sites More sharing options...
Chachi111769 Posted February 18, 2017 Report Share Posted February 18, 2017 Looks good Gordster 1 Quote Link to comment Share on other sites More sharing options...
dgman Posted February 18, 2017 Report Share Posted February 18, 2017 Looks good Gordie! Gordster 1 Quote Link to comment Share on other sites More sharing options...
DWSUDEKUM Posted February 18, 2017 Report Share Posted February 18, 2017 Very neat Gordie. How big is that? Thanks for sharing this with us. DW Gordster 1 Quote Link to comment Share on other sites More sharing options...
blights69 Posted February 18, 2017 Report Share Posted February 18, 2017 Very nice Gordie Thanks for sharing Gordster 1 Quote Link to comment Share on other sites More sharing options...
lawson56 Posted February 18, 2017 Report Share Posted February 18, 2017 I bet your Friend Loved it.Awesome job Gordie. Gordster 1 Quote Link to comment Share on other sites More sharing options...
Gordster Posted February 18, 2017 Author Report Share Posted February 18, 2017 Very neat Gordie. How big is that? Thanks for sharing this with us. DW Thank you DW,the size is 5.5 by 18 inches..That is about as long I can make it on my 16 inch delta. Quote Link to comment Share on other sites More sharing options...
Gordster Posted February 18, 2017 Author Report Share Posted February 18, 2017 It's hard to see the raised effect from the photo but that is a very nice sign. I bet it looks even better in real life where you can see the raised effect. Rob Thank you Rob..Because there is so many letters,I had to reduce the angle to about 4 or 5 degrees.This makes it raise just about an eighth of an inch. Quote Link to comment Share on other sites More sharing options...
Scrolling Steve Posted February 18, 2017 Report Share Posted February 18, 2017 Very nice Gordie ! Gordster 1 Quote Link to comment Share on other sites More sharing options...
DukeNukem Posted February 18, 2017 Report Share Posted February 18, 2017 Looks good. Jerry Gordster 1 Quote Link to comment Share on other sites More sharing options...
daveww1 Posted February 18, 2017 Report Share Posted February 18, 2017 very nice Gordster 1 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted February 18, 2017 Report Share Posted February 18, 2017 Great sign. Fine work. Gordster 1 Quote Link to comment Share on other sites More sharing options...
orangeman Posted February 18, 2017 Report Share Posted February 18, 2017 Maybe your friend should rename his place: "Dew Drop Inn" bb Gordster 1 Quote Link to comment Share on other sites More sharing options...
tuner Posted February 18, 2017 Report Share Posted February 18, 2017 You did a real nice job on that sign and protected it well. I made a small sign for my shop door years back used treated wood and only paint but mine did not last to long😟 Gordster 1 Quote Link to comment Share on other sites More sharing options...
Gordster Posted February 18, 2017 Author Report Share Posted February 18, 2017 You did a real nice job on that sign and protected it well. I made a small sign for my shop door years back used treated wood and only paint but mine did not last to longThanks Randy, I have had pretty good luck with the signs lasting.I have always made them from pine, stained and then the spar varnish. Maybe a combination of all three.Never got any complaints yet. Quote Link to comment Share on other sites More sharing options...
wombatie Posted February 19, 2017 Report Share Posted February 19, 2017 That looks terrific Gordie and thanks for the explanation on how to make them. Marg Gordster 1 Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted February 19, 2017 Report Share Posted February 19, 2017 I might just do that is it free board. great sign. Roly Gordster 1 Quote Link to comment Share on other sites More sharing options...
Gordster Posted February 19, 2017 Author Report Share Posted February 19, 2017 (edited) I might just do that is it free board. great sign. Roly Roly,if you give it a go..remember to get the letters to raise always cut Counterclockwise.to get them to inset,cut clockwise. Play with the angle to get the height you want. Here is one I did with just the 4 house numbers. You can see the letters are raised higher as I used about 7 degrees to make the cuts. Edited February 19, 2017 by Gordster Phantom Scroller 1 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted February 19, 2017 Report Share Posted February 19, 2017 A fellow asked me go make him a sign for his gate entitled Do Drop In.This is what I put together. It is 3/4 inch pine stained with dark walnut. Then given 3 coats of spar varnish. The letters I use just paint.I do not put spar on the white letters as they will turn yellow. The letters and horses are raised by tilting the saw table to the left.Cut Counterclockwise. I usually tilt the table around 7 degrees, but because of so many letters here I only went 5 degrees.The centers in the letters O and D, I cut clockwise which will recess that part back.These are fun to make and the raised letters set it off nicely. I don't know Gordie but are both pieces of wood 3/4" or can one be thinner than another?You did a nice job here! Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted February 19, 2017 Report Share Posted February 19, 2017 Roly,if you give it a go..remember to get the letters to raise always cut Counterclockwise.to get them to inset,cut clockwise. Play with the angle to get the height you want. Here is one I did with just the 4 house numbers. You can see the letters are raised higher as I used about 7 degrees to make the cuts. What size blade did you use ? Roly Quote Link to comment Share on other sites More sharing options...
newfie Posted February 19, 2017 Report Share Posted February 19, 2017 Cool sign Gord you did a great job with it. Thanks for sharing Gordster 1 Quote Link to comment Share on other sites More sharing options...
smitty0312 Posted February 19, 2017 Report Share Posted February 19, 2017 Very nice...... Gordster 1 Quote Link to comment Share on other sites More sharing options...
penquin Posted February 19, 2017 Report Share Posted February 19, 2017 Looks great, the angle idea is a winner. Thanks for showing it to us. jim penquin Gordster 1 Quote Link to comment Share on other sites More sharing options...
Gordster Posted February 19, 2017 Author Report Share Posted February 19, 2017 I don't know Gordie but are both pieces of wood 3/4" or can one be thinner than another?You did a nice job here! Thanks Kevin...that is just one piece 3/4 pine...the letters are part of the same board. Quote Link to comment Share on other sites More sharing options...
