Canuck45 Posted October 28, 2017 Report Posted October 28, 2017 Hi What's the difference between a #1 blade and a 2/0 blade? new2woodwrk and OCtoolguy 2 Quote
Dan Posted October 28, 2017 Report Posted October 28, 2017 It depends. If you look at Flying Dutchman 2/0 reverse tooth and Olsen 2/0 reverse the kerf and thickness are the same but the TPI is significantly different. No. 1 blades are generally a slight bit larger than 2/0 but that can vary between manufacturers. If you are considering buying one or the other check out the blade chart for the manufacturer for recommended use. That said, if one works better for your use just go with that blade size. OCtoolguy 1 Quote
Roberta Moreton Posted November 1, 2017 Report Posted November 1, 2017 I ordered a few different ones from the same manufacturer. I chose Olson, chose whichever you want. I wanted to see and try different blades to see for myself what the difference was. It did really help me understand. OCtoolguy 1 Quote
tomsteve Posted November 2, 2017 Report Posted November 2, 2017 in flying dutchman reverse tooth blades, a #1 is .026 wide,.011 thick, has 13 teeth per inch and 7 reverse teeth. a #2/0 is 022 wide, 010 thick, 15 teeth per inch, and 10 reverse teeth. heres the list for FD reverse tooth blades: Model Width Thickness TPI Rev Teeth Drill Bit SR #2/0 0.022 0.010 15 10 71* SR #1 0.026 0.011 13 7 68* SR #3 0.035 0.013 13 7 64* SR #5 0.037 0.015 13 7 60* SR #7 0.043 0.017 10 7 56* SR #9 0.050 0.018 8 7 1/16* SR #12 0.067 0.020 7 6 47* for the 2 way cut Model Width Thickness TPI Rev Teeth Drill Bit TC #2/0 0.027 0.008 15 Every 3rd 70* TC #1 0.030 0.011 15 Every 3rd 68* TC #3 0.035 0.013 13 Every 3rd 64* TC #5 0.036 0.015 13 Every 3rd 63* TC #7 0.043 0.017 10 Every 3rd 56* TC #9 0.050 0.018 8 Every 3rd 55* and the ultra reverse Model Width Thickness TPI Rev Teeth Drill Bit UR #2/0 0.027 0.008 15 Every 3rd 68* UR #1 0.029 0.011 15 Every 3rd 68* UR #3 0.031 0.013 15 Every 3rd 65* UR #5 0.037 0.015 15 Every 3rd 60* UR #7 0.043 0.017 12 Every 3rd 56* UR #9 0.053 0.018 12 Every 3rd 1/16* NC Scroller, OCtoolguy, txpitmaster and 2 others 3 2 Quote
OCtoolguy Posted November 2, 2017 Report Posted November 2, 2017 2 hours ago, tomsteve said: in flying dutchman reverse tooth blades, a #1 is .026 wide,.011 thick, has 13 teeth per inch and 7 reverse teeth. a #2/0 is 022 wide, 010 thick, 15 teeth per inch, and 10 reverse teeth. heres the list for FD reverse tooth blades: Model Width Thickness TPI Rev Teeth Drill Bit SR #2/0 0.022 0.010 15 10 71* SR #1 0.026 0.011 13 7 68* SR #3 0.035 0.013 13 7 64* SR #5 0.037 0.015 13 7 60* SR #7 0.043 0.017 10 7 56* SR #9 0.050 0.018 8 7 1/16* SR #12 0.067 0.020 7 6 47* for the 2 way cut Model Width Thickness TPI Rev Teeth Drill Bit TC #2/0 0.027 0.008 15 Every 3rd 70* TC #1 0.030 0.011 15 Every 3rd 68* TC #3 0.035 0.013 13 Every 3rd 64* TC #5 0.036 0.015 13 Every 3rd 63* TC #7 0.043 0.017 10 Every 3rd 56* TC #9 0.050 0.018 8 Every 3rd 55* and the ultra reverse Model Width Thickness TPI Rev Teeth Drill Bit UR #2/0 0.027 0.008 15 Every 3rd 68* UR #1 0.029 0.011 15 Every 3rd 68* UR #3 0.031 0.013 15 Every 3rd 65* UR #5 0.037 0.015 15 Every 3rd 60* UR #7 0.043 0.017 12 Every 3rd 56* UR #9 0.053 0.018 12 Every 3rd 1/16* Thanks for the info. I will print this out and save it. Quote
Canuck45 Posted November 3, 2017 Author Report Posted November 3, 2017 Thanks for the information. I will keep this by my saw. OCtoolguy 1 Quote
amazingkevin Posted November 20, 2017 Report Posted November 20, 2017 Too much too know new2woodwrk and OCtoolguy 1 1 Quote
WayneG Posted December 23, 2017 Report Posted December 23, 2017 On 11/2/2017 at 12:23 PM, octoolguy said: Thanks for the info. I will print this out and save it. you can find all this online at mikes workshop.com, it lists the specs for everyblade bobscroll, tomsteve and OCtoolguy 3 Quote
Greenie Posted February 12, 2018 Report Posted February 12, 2018 Tomsteve--great info, I too will print this and keep it handy OCtoolguy 1 Quote
bowers25 Posted February 13, 2018 Report Posted February 13, 2018 On 12/23/2017 at 10:13 AM, WayneG said: you can find all this online at mikes workshop.com, it lists the specs for everyblade I was not able to find any specs on FD blades.......where is it listed? OCtoolguy 1 Quote
JustLarry Posted February 13, 2018 Report Posted February 13, 2018 Every order I have received from Mike's includes a brochure showing specs for all of the blades. 13 minutes ago, bowers25 said: I was not able to find any specs on FD blades.......where is it listed? at Mike's workshop site select blades, select any blade and the specs for that "style" of blade will be shown. Larry OCtoolguy 1 Quote
bowers25 Posted February 13, 2018 Report Posted February 13, 2018 32 minutes ago, JustLarry said: Every order I have received from Mike's includes a brochure showing specs for all of the blades. at Mike's workshop site select blades, select any blade and the specs for that "style" of blade will be shown. Larry Roger That......Damn I should have looked a little hard.......I need this information.......Thanks for the help Larry!!! OCtoolguy 1 Quote
tgiro Posted February 13, 2018 Report Posted February 13, 2018 41 minutes ago, JustLarry said: Every order I have received from Mike's includes a brochure showing specs for all of the blades. at Mike's workshop site select blades, select any blade and the specs for that "style" of blade will be shown. Larry I looked on the latest Mikes Workshop page and the chart that Mike used to have there is gone. Wooden Teddy Bear bought Mike's business. I looked on their site and didn't see it either. Googling the chart resulted in the Olsen chart and the JGR Tough Little Blade chart. Wooden Teddy Bear may have the Flying Dutchman chart, but they aren't displaying it. OCtoolguy 1 Quote
JustLarry Posted February 13, 2018 Report Posted February 13, 2018 11 hours ago, tgiro said: I looked on the latest Mikes Workshop page and the chart that Mike used to have there is gone. Wooden Teddy Bear bought Mike's business. I looked on their site and didn't see it either. Wooden Teddy Bear may have the Flying Dutchman chart, but they aren't displaying it. At Mikes and WTB the specs are shown for each blade type. Select the blade and the specs for that blade are shown following the description of the blade. Here is sample from each site: I looked at these just a few minutes ago. Mikes - https://mikesworkshop.com/collections/blades/products/new-spiral WTB - https://www.woodenteddybearonline.com/x/product.php?productid=3403&cat=550&page=1 Larry OCtoolguy 1 Quote
tgiro Posted February 15, 2018 Report Posted February 15, 2018 On 2/13/2018 at 10:44 AM, JustLarry said: At Mikes and WTB the specs are shown for each blade type. Select the blade and the specs for that blade are shown following the description of the blade. Here is sample from each site: I looked at these just a few minutes ago. Mikes - https://mikesworkshop.com/collections/blades/products/new-spiral WTB - https://www.woodenteddybearonline.com/x/product.php?productid=3403&cat=550&page=1 Larry I saw those, but Mike used to have a PDF of the page he would send out with each of his orders. That seems to have disappeared. OCtoolguy 1 Quote
Rolf Posted February 15, 2018 Report Posted February 15, 2018 One of our club members has always said to ignore the blade numbers and only compare the TPI and other specs. I am doing a presentation tonight for our new members, part of the discussion will be this blade topic. I get a kick out of the comments people make " my FD 2/0 blade cuts so much faster than my Olson 2/0" it is therefore a better blade. The reality is the Olson 2/0 has 28 tpi vs the 15 on the FD. Who's blades are better is a different discussion, those can get ugly. OCtoolguy 1 Quote
don in brooklin on Posted February 15, 2018 Report Posted February 15, 2018 Great idea to copy out the sizes etc. I teach the Beginner scrolling course at our club and I give out the Olsen chart found at https://www.olsonsaw.net/wp-content/uploads/2016/01/2015-scrollchart.pdf I am a big FD Ultra Reverse user so I have every one use UR blades. #3 for BB and #5 for compound. I give out the pricing sheet if I have them but with this idea I I have created a PDF from the web site. May need some tweaking so if any one sees an error please let me know. I want to make into a spreadsheet eventually. When I discuss blades I do emphasize that they should try other blades until they find one they like for the work they do. flying dutchman.pdf OCtoolguy 1 Quote
OCtoolguy Posted February 16, 2018 Report Posted February 16, 2018 On 2/15/2018 at 7:13 AM, Rolf said: One of our club members has always said to ignore the blade numbers and only compare the TPI and other specs. I am doing a presentation tonight for our new members, part of the discussion will be this blade topic. I get a kick out of the comments people make " my FD 2/0 blade cuts so much faster than my Olson 2/0" it is therefore a better blade. The reality is the Olson 2/0 has 28 tpi vs the 15 on the FD. Who's blades are better is a different discussion, those can get ugly. This certainly makes a lot of sense. Matching the thickness of material being cut to a blade with the correct number of teeth would make a great difference in quality of finished product. Thanks for opening my eyes to that Rolf. Ray Quote
OCtoolguy Posted February 16, 2018 Report Posted February 16, 2018 (edited) On the subject of blades and mfgrs. have any of you ever tried blades from Otto Frei? Here is a link to a page on their website. I bought 2 gross of the 2/0 blades from them when I first got interested in marquetry and the instructor recommended them to his class. It seems that they are priced close to the more popular FD, Olsen, and Pegas blades. So far, I have had good luck with them but I'm not the most experienced or high volume scroller here by any means. Please let me know what you think. Ray http://www.ottofrei.com/Otto-Frei-Swiss-Jewelers-Saw-Blades-By-The-Gross-144-Pieces?custcol_of_xc_sawblade_size=11 Edited February 16, 2018 by octoolguy Quote
Bill WIlson Posted February 16, 2018 Report Posted February 16, 2018 Wow, those are some tiny blades! I can't imagine trying to use an 8/0 jewelers blade in an electric scroll saw. But it might be fun to try....once. Quote
OCtoolguy Posted February 16, 2018 Report Posted February 16, 2018 6 minutes ago, Bill WIlson said: Wow, those are some tiny blades! I can't imagine trying to use an 8/0 jewelers blade in an electric scroll saw. But it might be fun to try....once. Well, they specialize in tools for jewelers. They have larger sizes too. Ray Quote
