My main woodworking tool is an old Shopsmith. Years ago I had an electrician install a dedicated ceiling mounted 20amp circuit for that equipment. (They run better on a 20 amp circuit than a 15) Recently I broke off the grounding prone. For safety I want this fixed. The ceiling mounted circuit has an older style receptacle with two parallel slots, one for the hot and the other for the neutral.  I thought I'd just replace the receptacle on the Shopsmith, but all the 20 amp plug ends no longer have two parallel slots, ones at right angles. Geez I hope someone is following this. I can take pics if needed. Anyway - can I use a 15 amp or do I need to replace both ends???
Thanks for reading this.
What Dan said - most states have wiring codes. If you are running from a 20 amp breaker then the socket & plugs must be up to code. The stores in your state will only sell sockets and plugs that meet the code.
Giving electrical advice on a forum can be dangerous. It all depends on how much skill and knowledge the person doing the work has. To convert a 20A receptacle to a three prong is fairly  straight forward. Turn off the power to that receptacle, test to make sure the power is off. Remove the cover then the 2 screws holding the fixture into box. Loosen the screws hold the wires to the receptacle then remove the receptacle . You should have 3 wires for the receptacle , black - hot, white - neutral and a brass one, this is the ground. Attach the black wire to the brass colored screw, the white wire to the silver screws and the brass ( or green ) to the green screw. Install the receptacle back into the box and replace the cover. Turn the power back on and test to make sure all went well.
Dunno the exact name for that outlet type, but I see those at work all the time for copiers.  There's little pigtail adapters you can get, but I wouldn't trust those any longer than it takes to get the correct outlet/plug.  Check Granger or someplace like Ace, Tractor Supply, Lowes, or Home Depot, they should have 20a outlets with straight plugs.
Quick searches:
Grainger:  https://www.grainger.com/search/electrical/electrical-supplies/installed-wiring-devices-wall-switches-and-receptacles/straight-blade-receptacles?attrs=Amps+-+Plugs+and+Receptacles|20+A~ATTRS|20~ATTRS~~Type+-+Plugs+and+Receptacles|Straight+Blade&filters=attrs&searchQuery=20a+outlet&sst=4&tv_optin=true
Lowes: https://www.lowes.com/pd/Pass-Seymour-Pass-and-Seymour-CR20CC12-20A-125V-2-Pole-3-Wire-Grounding-Heavy-Duty-Duplex-Outlet-Brown/5001015459
Home Depot:  https://www.homedepot.com/p/Leviton-20-Amp-Commercial-Grade-Duplex-Outlet-White-R62-CBR20-00W/202066702
Prices vary (anywhere from $3 at HD to near $20 at Lowes) but I may have clicked on a multipack.
11 hours ago, Sparkey said:
I have been an electrician since 1976 and a 20 amp outlet has looked like this as long as I have known. If you have anything different it is not 20 amp 120 volt.
Good one Sparky!!! A picture is worth a thousand words!!!
