I like to combine scrolling and CNC when I can. This was a Steve Good scroll saw pattern, but it was easily vectorized and cut on CNC.
First pic shows it being cut on the table, second off the table and cleaned up a bit, 3rd with a coat of reflective aluminum paint.
Could have cleaned it up better, but this was more or less a proof of concept, and it turned out pretty well. Is about 12x12", 1/4 birch ,,,, And the only obvious mistake was not leaving bridges for the center parts of the 6 & 9.
I used a very small end mill to cut, at 60% feed rate - Took about 10 minutes to cut. Will probably stick some hands and clock works in it whenever I run into them.
I have no idea why it cut the 2 small holes in the face, must be some artifacts in the file that I wasn't aware of.
