Woodrush Posted December 30, 2021 Report Posted December 30, 2021 (edited) I have an excelsior 21 and was wondering if anyone has found a solution to stop the rear tension knob from moving. I was told to tighten the nut underneath the knob, but it's so tight, I can't move it. If I don't keep an eye on it, it will move an inch by the time I'm done a couple of projects Edited December 30, 2021 by Woodrush OCtoolguy 1 Quote
Woodrush Posted December 30, 2021 Author Report Posted December 30, 2021 Don't know why this posted twice. I don't see anywhere to delete one OCtoolguy 1 Quote
Norm Fengstad Posted December 30, 2021 Report Posted December 30, 2021 my Seyco had similar problem. I removed the tensioner bolt, then put a drop of blue loc-tite on the threads reinserted, proble solved Woodrush and OCtoolguy 2 Quote
Woodrush Posted December 30, 2021 Author Report Posted December 30, 2021 40 minutes ago, Norm Fengstad said: my Seyco had similar problem. I removed the tensioner bolt, then put a drop of blue loc-tite on the threads reinserted, proble solved Will that affect if I want to move it. I do sometimes to get a more aggressive cut OCtoolguy 1 Quote
OCtoolguy Posted December 31, 2021 Report Posted December 31, 2021 8 hours ago, Woodrush said: I have an excelsior 21 and was wondering if anyone has found a solution to stop the rear tension knob from moving. I was told to tighten the nut underneath the knob, but it's so tight, I can't move it. If I don't keep an eye on it, it will move an inch by the time I'm done a couple of projects I took a wide rubber band and wrapped it around the tension rod just under the knob. A couple of wraps and then stretch down to one of the bolts on the side of the saw. Just a way to keep it from turning on its own. Gerry rig but it works. Woodrush and munzieb 1 1 Quote
kmmcrafts Posted December 31, 2021 Report Posted December 31, 2021 8 hours ago, Woodrush said: Will that affect if I want to move it. I do sometimes to get a more aggressive cut Probably depends on how often you turn it as to how long it'll last. I did blue ( make sure to use the blue otherwise you may never turn it again ) loc-tite a couple years ago and have turn it a handful of times over the couple years. I'm now just starting to have a very slight movement on it's own again. Maybe about once a month I have to readjust it. I'll likely take it apart again this summer and add some more loc tite.. OCtoolguy and Woodrush 1 1 Quote
Woodrush Posted December 31, 2021 Author Report Posted December 31, 2021 8 minutes ago, kmmcrafts said: Probably depends on how often you turn it as to how long it'll last. I did blue ( make sure to use the blue otherwise you may never turn it again ) loc-tite a couple years ago and have turn it a handful of times over the couple years. I'm now just starting to have a very slight movement on it's own again. Maybe about once a month I have to readjust it. I'll likely take it apart again this summer and add some more loc tite.. I don't turn it that often so that is probably the only solution. OCtoolguy 1 Quote
Wichman Posted December 31, 2021 Report Posted December 31, 2021 There is another solution, but I would only use it as a last resort. I have used this method myself but still: Mark where the nut sits on the threaded rod. Using a small pair of vice grips, open the jaws until they do not contact the thread when closed. Slowly, about a quarter turn at a time tighten the jaws so that threads of the rod are just slightly crushed. The crushed threads will resist movement due to vibration. I used this technique on a very small (2mm) machine screw that needed occasional adjustment (once a week to once a month, depending). This worked for 5+ years at which time I repeated the process. I was worried that even blue threadlock would be permanent. OCtoolguy and Woodrush 2 Quote
Roberta Moreton Posted December 31, 2021 Report Posted December 31, 2021 I just keep an eye on it and adjust when needed. Woodrush and OCtoolguy 1 1 Quote
FrankEV Posted December 31, 2021 Report Posted December 31, 2021 A piece of Blueu tape holds it in place on my Pegas. Not pretty but works. scrollingforsanity, Woodrush and OCtoolguy 3 Quote
xocd Posted December 31, 2021 Report Posted December 31, 2021 Would a jam nut under the tension knob and against the body of the saw work? xocd Woodrush 1 Quote
Woodrush Posted December 31, 2021 Author Report Posted December 31, 2021 5 hours ago, xocd said: Would a jam nut under the tension knob and against the body of the saw work? xocd That might work OCtoolguy 1 Quote
OCtoolguy Posted December 31, 2021 Report Posted December 31, 2021 I think Frank has the best answer. Blue tape strategically placed should do the trick. FrankEV, Woodrush and scrollingforsanity 3 Quote
