Total newbie, here. Making some door jamb strike plates. Right now just trying to cut in a straight line. I clamped down a board as a fence. Lowest speed setting. Pushing slowly. Directly on saw table; no sandwiching of the brass or taping of its surface.
The cut veers to the right, away from the desired cut line. No idea why.
Blade: .012" x .029" x #2 x 20 TPI - Skip Tooth
Thoughts?
I've read this is doable on a scroll saw. But maybe I really need to get a band saw?
Thoughts?
The blades will drift just like a bandsaw. You must figure out the drift and set your fence accordingly. Pegas blades don't drift as much as other brands because they are ground rather than stamped.
