jerry1939 Posted December 10, 2015 Report Posted December 10, 2015 Hi All,. I am having fun/frustration learning Inscape. Re: Lines equal distance from each other. For example - Drawing a (candy cane)(Victorian sleigh)(French curve). I can do parallel straight lines by starting at a top or side ruler. On a candy cane example, can make 2 half circles and attach them to the straight lines, but am currently guessing at the line spacing for the curves. Is there a better way? Please and Thank You, jerry Quote
Travis Posted December 10, 2015 Report Posted December 10, 2015 I'd make a straight line, then add a node part way down (about a 3rd down). Pull the top node to the left of the middle node so you have an upside down L shape. Select the horizontal line between the two nodes and push up to make a curve. Then bend it into a candy cane shape. Thicken up the stroke to something really wide. Then go to Path>Stroke To Path to make it into a shape. From there, you have your basic candy cane shape that you can tweak. Let me know if that doesn't make sense. Perhaps I can put together a video this weekend demonstrating it. woodworker13403A and bobscroll 2 Quote
amazingkevin Posted December 11, 2015 Report Posted December 11, 2015 (edited) Are you sure that's all you do is wash bottles ,My word the stuff that stays in your head.,Terrabites! Edited December 11, 2015 by amazingkevin Quote
jerry1939 Posted December 11, 2015 Author Report Posted December 11, 2015 Travis, THANK YOU SIR !!!! jerry Quote
