Well here's a glimps of my projects that showed up from 3 hours away.1-24"   3-14"  2-8"  and 6-6" walnut eagles.Some will be unplanned ,two i think.I print my patterns colorful so i can see them better with "Rapid Resizer.com"some are 1/2' thick and up to 1" thick walnutpost-1607-0-28099500-1461932682_thumb.jpgpost-1607-0-59523500-1461932703_thumb.jpgpost-1607-0-70863700-1461932720_thumb.jpgpost-1607-0-52205300-1461932752_thumb.jpgpost-1607-0-13530900-1461932793_thumb.jpgpost-1607-0-24358100-1461932846_thumb.jpg
Looks like you have your work cut out for you !......Those will look good in walnut Kevin !
thanks Steve ,the 6"ones were an ordeal to cut .slow as you go and press down tight so the blade only cuts what you let it.I had to use a tiny tiny drill on many places on the 6" eagles .cutting time was 2.5 hours on them.
