jerry1939 Posted January 17, 2018 Report Posted January 17, 2018 It was on the news that President Trump volunteered for a COGNITIVE FUNCTION TEST along with his physical. I googled "take cognitive function test" & took it. Interesting/informative results. Said I need to get off of my lazy a_____ more & consume less coffee & sugar. (Whenever I have a blood test, my sugar level is normal). Scored much better than I expected. The test takes about 15 minutes. Be sure to read each set of instructions carefully. It tells you up front that you will not be able to finish each set. Definitely need a laptop & mouse. http://cft3.foodforthebrain.org/ Lucky2 and Scrolling Steve 2 Quote
spirithorse Posted January 17, 2018 Report Posted January 17, 2018 If you run for president, Jerry, you have my vote! God Bless! Spirithorse Quote
amazingkevin Posted January 18, 2018 Report Posted January 18, 2018 On 1/16/2018 at 9:56 PM, jerry1939 said: It was on the news that President Trump volunteered for a COGNITIVE FUNCTION TEST along with his physical. I googled "take cognitive function test" & took it. Interesting/informative results. Said I need to get off of my lazy a_____ more & consume less coffee & sugar. (Whenever I have a blood test, my sugar level is normal). Scored much better than I expected. The test takes about 15 minutes. Be sure to read each set of instructions carefully. It tells you up front that you will not be able to finish each set. Definitely need a laptop & mouse. http://cft3.foodforthebrain.org/ i'll try to find time to take it,thanks !!!!!!!!! Quote
