Hi Amber.  I think that you posted your own pattern.  Print as many copies as you want layers.  Cut one copy of each color.
A trick I learned;  Your picture shows birds not attached.  Save the "scrap" that you cut those out of. For gluing, I prop that scrap up on craft sticks.  Apply glue
 to the birds & drop them into the scrap for positioning.  This method has much more merit when aligning individual letters for gluing.
jerry
Would add to my above posting.:
     a.  For the top layer, scribble the lines that will be cut for a lower layer, or preferably;
     b.  Use a yellow highlighter to mark what you want to cut for the top layer.
Lay the cut top layer onto what will be the 2nd layer & draw around all the interior cuts that you made in layer one.  Use your highlighter on the lines you drew from layer one.  Cut that, plus other interior cuts for layer two.  If there is layer three, repeat drawing around layer two onto layer three.
Let the pattern on the "top" layer.  After the interior cuts have been made on all the layers, glue them together & saw the perimeter.
Certainly hope that you can understand what I am trying to suggest.  I sure as  heck can't !!!!!!!  😁
jerry
On 7/9/2018 at 1:06 AM, Amber R. King-Southern said:
I was thinking 4. That including the back
Yes, that was my thought.  I think in the end it would look more like this tho.   Also, how would you handle the head?
Russell
