Drill a hole in the black between the two teeth.  Use a small bit that will fit in the black. Like a #60 or smaller.  Same with the lip.  I can't tell how big that area is from the picture.  You of coarse may have to go to a smaller blade to cut that area.  Doesn't matter where you drill the hole to start... as long as it fits in a black area.
Is that what you are asking?
  • 1 month later...
One tool I've found to help drilling the tiny entry holes square is a plunge router base for my dremel (Huge thanks to member MrsN. It was in reading one of her posts a while back that I learned of this). I had been using a drill press for the longest time but found it diffucult at times to get to the inner holes in some of the larger works. Using the router with my dremel allows my to drill the holes exactly where I need them, and if I need an entry hole at say 4 degrees, I simply shim one side of the base to get the angle needed.
Chris
Edited by Hawk
