TerryB Posted March 27, 2015 Report Posted March 27, 2015 I want to create a pattern in inkscape that has the text in a spiral similar to the one in the spring edition of Scrollsaw woodworking magazine. I wrote to the author to see if perhaps he'd used inkscape but he hadn't. Are there any tutorials out there that demo this or do you guys have any thoughts. I've attached a pic of what im talking about. Terry Quote
bobscroll Posted March 27, 2015 Report Posted March 27, 2015 To be honest Terry I haven't done that myself, There is a tutorial on here telling you how to put "text on a path" But I don't know if it talks about what you are wanting, I might have a go at it myself, Bob Quote
bobscroll Posted March 27, 2015 Report Posted March 27, 2015 Hello Terry, I just played around with Inkscape and I managed to put text on a spiral! 1 Type in Capitals:THE BROWN COW JUMPED OVER THE MOON it's text. 2 Click on the left tool bar for the Spiral, Create your spiral of a decent size, Then convert it to a "Path" 3 Select your text and spiral, Then on the tool bar at the top select "Text" and click on "Text to Path" and low and behold your Text has attached it's self to your Spiral. O.K. Terry, Bob Quote
Scrolling Steve Posted March 27, 2015 Report Posted March 27, 2015 Bob, I think you were a Jedi Knight in a previous Life! Quote
TerryB Posted March 27, 2015 Author Report Posted March 27, 2015 Thanks Bob -- give it a try right now. Quote
TerryB Posted March 27, 2015 Author Report Posted March 27, 2015 Tried it - its a good start, now just need to figure out how to get them all connected. -- messing around time. bobscroll 1 Quote
Fab4 Posted March 28, 2015 Report Posted March 28, 2015 (edited) Hi Bob/Terry: Curiosity got the best of me on this one. I tried it, and this is what I came up with. I know it's not ready to be cut but I just wanted to try it to see what the outcome would be. I just wrote the saying over and over - I think it was 5 times, maybe 6 then just put text on path. A little more time and it would be ready to cut. Thanks Bob for the quick tutorial Thanks Terry for asking about it. Fab4 Edited March 28, 2015 by Fab4 Quote
Gordster Posted March 28, 2015 Report Posted March 28, 2015 Great stuff, I have to give that a try also....Good going Fab4..looks like you have a handle on it. Fab4 1 Quote
bobscroll Posted March 28, 2015 Report Posted March 28, 2015 Hey Paul Fab4, You nailed it! You did it better than me Bob Fab4 1 Quote
Fab4 Posted March 28, 2015 Report Posted March 28, 2015 Hey Paul Fab4, You nailed it! You did it better than me Bob Hi Bob: Thanks but: I doubt that very much. I followed what you wrote and this is the end result I would have gotten nowhere, otherwise. Thanks Gordie, appreciate the reply Fab4 bobscroll 1 Quote
TerryB Posted April 1, 2015 Author Report Posted April 1, 2015 Thanks Guys, And Fab4 I tried that site you mentioned and it works about the same as inkscape, just fewer options. The problem now is how to get the letters in the spiral to touch the ones above so that it can be cut out. I think I'll have to make each letter an object then move them to the spiral manually. Still working it. Terry Quote
Fab4 Posted April 1, 2015 Report Posted April 1, 2015 (edited) Hi Terry: After reading your post I went back to Inkscape to play When you click on the spiral, change the number where it says Turns keep an eye on the spiral. The letters will eventually touch. Then you can turn the letters to objects and you will have what you want. Path - object to path - ungroup - Path - Union (as a reminder) You may have to play around with the spacing(kerning) to get the letters to line up properly Keep me posted as to how you are doing Thanks Fab4 Forgot to say The way you mention above would work too Edited April 1, 2015 by Fab4 Quote
TerryB Posted April 3, 2015 Author Report Posted April 3, 2015 very COOL Fab4. Perfect. Just have to arrange the words backwards so it spirals from the outside in. Inkscape is so cool (and price is right). Going to now mess around with kerning to see if I can actually do this. Terry Fab4 1 Quote
CATRK Posted April 28, 2015 Report Posted April 28, 2015 To get the letters the correct direction, 10 draw the spiral 2) flip the spiral horizontal 3) Reverse the path, to do this convert the spiral to a path(PATH- Object to Path) and than reverse the nodes by reversing the path (PATH-reverse) 4)Put the text on the path. You will have to adjust the spiral for teh length of the text and adjust the text and kerning appropraitely. I'm working on the lyrics for AMAZING GRACE. Hope this helps. bobscroll 1 Quote
