In Part 2 I showed how I used the wrong bearing and as a result had to go back to square 1 to mill new side pieces. In this section I'll show another mistake and how I patched the part rather than replace it. In cutting the grooves this piece caught on the edge of the table saw insert instead of the fence resulting in a out of position cut. post-18045-0-91234600-1432660737_thumb.jpg
I thought it would be easier and faster to patch this mis-cut groove. I dug through the off-cut pile looking for stock with the right grain character. Then I cut a thin section of this stock and continued forming it with the plane and a dovetail saw. Here's the patch before putting it in place.
I glued it into position, because I couldn't use a clamp so I pressed it into position with couple of shims. I used paraffin wax on these first so glue couldn't stick to them.post-18045-0-33745700-1432661224_thumb.jpgpost-18045-0-59387500-1432661169_thumb.jpg Then I used a chisel and sand paper to finish fitting the patch.
The repair completed I cut the splines which will add glue surface and strength to all the end joints I'm gluing together. post-18045-0-49871400-1432661459_thumb.jpgpost-18045-0-67128800-1432661493_thumb.jpg
Like many woodworkers sanding is the least favorite step, but gluing often gives me heart burn. I dry fit all the splines for this project. I made several small adjustments paring grooves sizes with my sharpest chisel and sanding the splines for better fit still.....it took about a half hour to get one end glued.   Here it is glued and clamped. I used the square to ensure the ends would be square to the sides. post-18045-0-31574900-1432661733_thumb.jpg
Edited by oldhudson
