A Judy Gale Roberts pattern.  Measures 17.5 x 22 inches.  85 pieces of Aromatic Cedar, Aspen, Basswood, Blue Pine, Canarywood, Mahogany, Padauk, Peruvian Walnut, Poplar, Spalted Maple, Walnut, Wenge, and Yellowheart.
Such a site to see,Lots of hard earned work here,payed off nicely
The large balloon, does come right off the frame  The center is 1/2 inch higher than the outer edge, then drops down 1/4, and then the outer edge drops down to the surface of the piece.  so in essence, the center of the balloon, is about 1/2 to 5/8 of an inch above the surface of the frame.  This was a tricky one.  The balloon had to be right, so I built that before doing anything else. I then cut the frame and attached it to the backing, and built the rest of the piece inside the frame so I could insure a good tight fit.
