woodknots Posted December 26, 2016 Report Posted December 26, 2016 I'm looking at buying a spindle sander and was wondering if anyone has or knows anyone who has this sander. I really want one that has a tilting table and goes down to a 1/4' sleeve. I know the jet also has these features but out of my price range at this moment. Thanks Jeff Quote
Lucky2 Posted December 27, 2016 Report Posted December 27, 2016 Sorry Jeff, I can't help with this model, I own a Ridgid Spindle/Belt Osillating sander and I love it. Len Quote
amazingkevin Posted December 27, 2016 Report Posted December 27, 2016 I'm looking at buying a spindle sander and was wondering if anyone has or knows anyone who has this sander. I really want one that has a tilting table and goes down to a 1/4' sleeve. I know the jet also has these features but out of my price range at this moment. Thanks Jeff i bought a spindle sander and never used it i can't get to it. Jim Finn 1 Quote
Jim Finn Posted December 27, 2016 Report Posted December 27, 2016 I had a chance to buy a spindle sander from a friend. A different friend loaned me his and I tried it out. After using it a while I brought it back to him and told my other friend that I did not want to buy his. I was using this tool to sand, band saw boxes. LOTS of sanding required in making them. I discovered that I prefer soft pnumatic drum type sanders mounted in my drill press. I also found a way to avoid most of the sanding I was doing in making the band saw boxes. Instead of sanding the interiors of the box and of the drawers I flockked them. Better finished product and a bit less sanding required. I made and sold 31 of them last year but I am not sure I want to make them again. Requires lots of wood, and time. woodknots 1 Quote
hawkeye10 Posted December 27, 2016 Report Posted December 27, 2016 I'm looking at buying a spindle sander and was wondering if anyone has or knows anyone who has this sander. I really want one that has a tilting table and goes down to a 1/4' sleeve. I know the jet also has these features but out of my price range at this moment. Thanks Jeff I bought the Ridgid sander at Home Depot. I like it because it has the spindle and belt sander. Also the table tilts like you want. It also has a life time warranty. I don't use it every day but it earns it's keep. http://www.homedepot.com/p/RIDGID-Oscillating-Edge-Belt-Spindle-Sander-EB4424/100061671 woodknots 1 Quote
Rolf Posted December 28, 2016 Report Posted December 28, 2016 (edited) It seems to have good reviews . One comment that was made is the the table insert is slightly recessed creating a small ridge that can snag the wood or if you are not paying attention will allow the wood to skew just slightly,The Jet has the same issue. I sometimes put a another thin piece of wood on the top, until I put in some set screws so that I can tweak it. It is not a major issue as long as you are aware of it. I have the Jet, I absolutely love it. It really helps me when I need to do some tweaking when doing intarsia. and the 1/4 in spindle is my most used Edited December 28, 2016 by Rolf Quote
woodknots Posted December 28, 2016 Author Report Posted December 28, 2016 It seems to have good reviews . One comment that was made is the the table insert is slightly recessed creating a small ridge that can snag the wood or if you are not paying attention will allow the wood to skew just slightly,The Jet has the same issue. I sometimes put a another thin piece of wood on the top, until I put in some set screws so that I can tweak it. It is not a major issue as long as you are aware of it. I have the Jet, I absolutely love it. It really helps me when I need to do some tweaking when doing intarsia. and the 1/4 in spindle is my most used The zero clearance inserts for my bandsaw were the same way. I bought some of the duct tape by gorilla glue, which is thicker than most, I put it on the bottom and it made it level so it should work for this as well. The tilting table was a big decider but the 1/4" spindle was the main reason for me. Quote
