This Window has popped up lately saying the there will be some type of UPDATE going to
happen in the near future.  Being on the Novices side of computers I would Appreciate any
help in understanding.
Attachment shows as far as I have went so far....  Would the next stop to be....I ACCEPT....  ?
Thanks for any Info on this.   Danny  :+}
Danny
I went through the same thing. The update takes quite a while to complete. The window you are showing is your privacy settings and all mine are turned on. It seems to have a lot of advanced features and will load Edge when completed and show you updates. I think there is 19 little click through like modules to help explain after. Just give yourself some time for this update to run and explore after completed.
Thank You Wayne for this info.  Will keep this info. when the update has started.
By the way....You said Edge will be loaded.  Any problem if I use Firefox which I have used for Years?
I have Never used Edge or even know anything about it.              Thanks again...........Danny  :+}
Well for what its worth....   I did go thru the motions of the Windows 10 Update etc.
Lot of Waiting.  Took approx. 50 minutes to be able to use the PC.
Not really sure how things might of changed If the did, but have been using the PC
for an hour and NOTHING HAS CHANGED THAT I CAN TELL.    Danny  :+}
Goodf or you Danny ,i don;t like it anymore than you do!
