Vector01 Posted July 28, 2010 Report Posted July 28, 2010 I was having problems cutting patterns. My distance glasses were no help and my bifoculs were just as bad. I had my routine eye exam a few months ago and I explained my problem to the doctor. He asked me some questions concerning working on the scroll saw and said "I might have a solution." He came back with an odd pair of glasses and said try these. We set up a mock pattern (simple pencil sketch) at the distance I normally work at. The lines were clear and sharp. I said "these are great. What are they?" He explained that they were occupational glasses. He prescribed them to people who had jobs that entailed being able to see fine details like electronic assembly, working on circuit boards, etc. If you wear glasses and are having problems cutting patterns keep this in mind the next time you see your eye doctor. Quote
Travis Posted July 28, 2010 Report Posted July 28, 2010 Interesting. I never heard of that. Are they based on your eyes or are they just magnifiers? Quote
Vector01 Posted July 28, 2010 Author Report Posted July 28, 2010 He had reviewed my exams and made adjustments to the lenses (on the occupational glasses) before I tried them (they had different lenses attached). He rattled off some numbers to his assistant and they gave me a seperate prescription for them. They have also improved my ability to see my PC screen. They very well could be some type of magnifiers. I never asked. I have been able to reduce the width of lines on my patterns in Gimp to 0.25 pxl's as opposed to the default 1.0 pxl. I can cut the lines like a surgeon now Quote
greasemonkeyredneck Posted August 10, 2010 Report Posted August 10, 2010 I need to check into that. I'm actually supposed to wear glasses. I gave them up long ago though. Everytime they changed my prescription, they did great for a while. Then it would get where things are always either too far away or too close. I'd have to move everything to the correct distance from my face so I could see. Hey! That's what I was doing without the glasses, so why bother with them. Maybe what you're talking about though would help keep me from having to take as many breaks from the saw. I have to stop often and rest my eyes or everything starts to run together as the headache starts to set in for the long haul. Quote
amazingkevin Posted August 11, 2010 Report Posted August 11, 2010 I need glasses to find my glasses.100 power glasses i can see very good with but don't wear them .When i scroll i uses 375 power.350 won't let me see the teeth on the blade.I pay a dollar for them at the dollar store.They are plastic lens but work for me.Real glass lens are very nice to look through,sharper and clearer . Quote
wedo scroll Posted August 11, 2010 Report Posted August 11, 2010 I've gone to the dept stores and gotten glasses off the shelf. I have a pair for computer, a pair for reading and a pair for woodworking. Each is a different focal length or strength. The easy way to do it is measure how far away you are from what you are looking at. Then bring a sample of what you want to see to the store and using different strength glasses approximate the same distance and look for the clearest vision. Works like a champ. Just get the lowest power glasses that will give you clear vision, as that will have the most variance in distances. The higher the power the more you tighter the distance must be. Also use plastic as they can also work well as safety glasses in case something breaks. Bill Quote
cjswoodcrafts Posted October 30, 2010 Report Posted October 30, 2010 hey all, i usually wear reading glasses 3.0 strength, the highest they have at the dollar store, when i do a very detailed pattern i use my lighted magnifier thats kind of like a hat, like jewelers wear. which i got it on ebay, i had an eye exam 2 yrs ago, doc scribed me glasses, 150 bucks later, and now all they are good for is to watch tv, cant read with them, Quote
Lastchance Posted October 30, 2010 Report Posted October 30, 2010 Hi All, I am a new glasses warer. Doc has me in a pair of linless byfocals. Have real good distance vision, but need longer arms to read up close and such. Think I am going to make a trip that way today and see if I can find a 3.0 pair as mentioned above. Great thred. Thanks for bringing this one up. May save me a bunch of time and headake Chance Here's a follow up since I could not get away. What do you all think about these? http://www.amazon.com/DPG59-130C-Reinfo ... 396&sr=8-4 THEY HAVE THEM IN SEVERAL STRENGTHS!! Quote
