One of the biggest challenges in the construction of this box was figuring out how to make the intersecting sections of the double miters strong enough . Normal end grain miter joints are pretty weak without using some sort of dowel of biscuit to reinforce them and in this case a double miter was even more challenging to strengthen. After playing with different options I decided to go with drilling multiple holes in the ends of the miters which will greatly add to the glue surfaces. I also decided to use a 2-part epoxy for the glue-up instead of wood glue.
I used a 5/64†high speed cutter in the dremel tool to make the holes in the end-grain miters.
marbleweddingbox028.jpg?t=1282835308
I went ahead and did the final sanding and applied 2 coats of satin poly to all of the components before the glue-up to make it easier to clean up any glue squeeze out.
The glue up went real good and I had very little sanding to do .
I decided to use 2†brass hinges to attach the lid which I had to mortise in so I set up the router table with a 1/2†straight bit and using stop blocks and running a couple of test pieces dialed in the correct distances for the mortises.
Set up for hinge mortises
marbleweddingbox033.jpg?t=1282835308
marbleweddingbox034.jpg?t=1282835308
Once one side of the mortises are done then I shifted the stop blocks over to the second set of reference marks to complete to other mortises.
Clean up the round corners with a chisel and am good to go
marbleweddingbox035.jpg?t=1282835308
So here are the photos of the box after the hardware is installed. Still have to apply another coat of finish and install to bottom liner. The completed box weighs in at 9 1/2lbs.
marbleweddingbox032.jpg?t=1282835308
marbleweddingbox030.jpg?t=1282835308
This was a challenging project and I learned a few things that will come in handy someday .
Mike ,that is one super nice box.Your really something when it comes to good enough is not good enough projects.I'd be happy as a lark to own a box as this one takes the cake.Truely innovative design,none better.For such a fancy box ,not that i'm complaining but a tweck of an added chain catching tray on both sides, so it doe'nt snag on jewery or the like would sweeten the deal a tad more.I'd bet you could drive a truck over this kind of construction and not phase it.Great craftsmanship Mike! :)
  • 2 weeks later...
