I have made a few of these boxes in the past. The 1/2" poplar joint box sides are easy to do with my I-box Jig. Routered a groove in the bottom for a 1/4" base. The dome is the more complicated part. I actually build a 2nd box frame and cut out the sides of the dome from that. I bend the 1/8" top in my steam box and use the cutout box frame as a mould to clamp and hold the top in place. I glue the top with Titebond 3. I used 2 side tape the top to the base and and sand everything even with the belt sander. I used a 9mm stop hinge for the top. Finish is shellac with several coats of Black Shellac. My wife did her wonderful paint work on the top and sides.
