CSull Posted May 16, 2021 Report Posted May 16, 2021 I see a lot of ads now for small laser burners, and this has caught my interest. I was wondering if any of you use one? I am concerned with my limited tech skills that learning to use one might make me regret the purchase. Thanks in advance for any thoughts on the subject. new2woodwrk and pete44 2 Quote
LarryEA Posted May 16, 2021 Report Posted May 16, 2021 (edited) To me using a Laser burner is not a buy and use machine. I see more to learn than I want to tackle, but then that's me. To me it's kin to learning how to use a pyro burner. Edited May 17, 2021 by LarryEA WayneMahler and new2woodwrk 2 Quote
Rockytime Posted May 17, 2021 Report Posted May 17, 2021 I have problems with just my cell phone! new2woodwrk, LarryEA and amazingkevin 3 Quote
meflick Posted May 17, 2021 Report Posted May 17, 2021 (edited) First let’s me say, there have been several discussions in the past about using these small diode lasers here on the forums so it might help you get more information if You search the forums for those older threads. If I find any, I’ll post the links. I and several others have one. Like many things, you will find it easier to use and run when you are comfortable with using a computer and software that is necessary to run them. If you have specific questions, I and others would be happy to try to answer them. The small inexpensive diode lasers are not for cutting wood projects, they are more for burning. Or “engraving” images, signatures, etc. That is what I got mine for. If you are wanting to do actual cutting, you would need a much stronger, much more expensive CO2 type lasers. Edited to add: here are links to two of the older discussions. https://www.scrollsawvillage.com/forums/topic/40331-anyone-have-an-ortur-laser/?tab=comments#comment-440280 and then https://www.scrollsawvillage.com/forums/topic/38399-im-thinking-about-getting-this-cnc-laser-engraving-machine/#comment-423370 Edited May 17, 2021 by meflick LarryEA, BadBob, CSull and 3 others 5 1 Quote
amazingkevin Posted May 24, 2021 Report Posted May 24, 2021 On 5/17/2021 at 3:33 PM, meflick said: First let’s me say, there have been several discussions in the past about using these small diode lasers here on the forums so it might help you get more information if You search the forums for those older threads. If I find any, I’ll post the links. I and several others have one. Like many things, you will find it easier to use and run when you are comfortable with using a computer and software that is necessary to run them. If you have specific questions, I and others would be happy to try to answer them. The small inexpensive diode lasers are not for cutting wood projects, they are more for burning. Or “engraving” images, signatures, etc. That is what I got mine for. If you are wanting to do actual cutting, you would need a much stronger, much more expensive CO2 type lasers. Edited to add: here are links to two of the older discussions. https://www.scrollsawvillage.com/forums/topic/40331-anyone-have-an-ortur-laser/?tab=comments#comment-440280 and then https://www.scrollsawvillage.com/forums/topic/38399-im-thinking-about-getting-this-cnc-laser-engraving-machine/#comment-423370 Thank you Brenda I never knew anything about them till you!!! meflick 1 Quote
