grampa Posted August 15, 2024 Report Posted August 15, 2024 Hi, I am after a word art pattern with the names Adele, Stuart, Jack , Jack is the son so not sure of position of name thanks.... Paul Quote
don in brooklin on Posted August 17, 2024 Report Posted August 17, 2024 Hi Are you looking for word in word. I have put 3 names but need last name. Are you looking for something to sit on a shelf. Could do a names for a picture type Just need some direction Thanks Quote
grampa Posted August 17, 2024 Author Report Posted August 17, 2024 Hi Don, its to sit on a shelf, the last name is Mill if you can fit it in it would be great, thanks Quote
don in brooklin on Posted August 18, 2024 Report Posted August 18, 2024 HI Paul Attached is my typical Word in Word. It uses a little different font that is a little more delicate so please check over. This could be made to sit on a shelf. I would cut in thicker wood like 1/2 and then use 1/4 backer. You could also make a base. I was started to work on a name block but I need to rethink. Will get back to you. Take a look and let me know what you think. mill2.pdf multitom 1 Quote
grampa Posted August 18, 2024 Author Report Posted August 18, 2024 That's perfect thank you Don..... Paul Quote
