I asked about what clamps it uses.  The seller sent me this picture.  He us very responsive.  sent a picture as I was typing in asking for a picture.  He is selling it for a friend.  That always make me hesitate some.   I think this would be the top clamp. Is the bottom on similar?
That's a 226VS Ultra.. In the bag it appears to have a few blade holders. That clamp is the bottom one unless they upgraded to the new style upper clamp. The old style isn't easily removed as it is held in with a roll pin and has to be pressed out. I upgraded one of the saws I had and it replaces the whole front nose of the upper arm and then the clamp is removable..
Those lower blade chucks are around $20 each i think so the more you get the better.. I like to take a paint marker and mark what number blade I use for certain clamps.. This way I can preload several blades and if i forget what I loaded before they get used I can look at my number I put on it..That way if a projects requires me to use several different sized blades I don't have to change them out in the clamp too..
Seems like it's a pretty decent saw for the money if it runs good etc.
I think this saw is newer than a 1998 as I have the same saw but this one has the newer style logo on the side. I believe they made this up until 2005 ish.
This has two different positions in the lower arm to insert that clamp. The position closes to the front is for a finer detail cut or cutting thin stock.. and the rear slot os for a more aggressive cut for thicker stock..
