Phantom Scroller Posted December 23, 2013 Report Posted December 23, 2013 OK Folks. I know the is an odd one but all you airbrushers out there, do you ever water down acrylic paint for air brushing and if so what do you use to thin it for the airbrush gun as the proper stuff is double the price. Roly Quote
ChelCass Posted December 23, 2013 Report Posted December 23, 2013 The acrylic paint I use if water based so I use water to thin it down. Mainly you don't want to have your paint so thick it clogs the sprayer. Several thin coats is better then one thicker one. Phantom Scroller 1 Quote
Phantom Scroller Posted December 23, 2013 Author Report Posted December 23, 2013 The acrylic paint I use if water based so I use water to thin it down. Mainly you don't want to have your paint so thick it clogs the sprayer. Several thin coats is better then one thicker one. Judy do you get a nice even spray using water and what amount do you add to the acrylic as I use water based as well is the consistency OK. Roly Quote
Ron Johnson Posted December 23, 2013 Report Posted December 23, 2013 Hi Roly I only use water based acrylic paint and distilled water for thinning. I usually run distilled water through the air brush at the start and end. Phantom Scroller 1 Quote
amazingkevin Posted December 24, 2013 Report Posted December 24, 2013 mix it with water for the airbrush to the consistence of milk for good results Just a little thicker than water. Phantom Scroller 1 Quote
spirithorse Posted December 24, 2013 Report Posted December 24, 2013 Hi, Roly, You should have received a tester with your air-brush to check the consistency of the paint. Like Kevin said, about the thickness of milk. In the tester, you want the paint to drip out of the nozzle rather than running through it. Good luck and God Bless! Spirithorse Quote
Phantom Scroller Posted December 24, 2013 Author Report Posted December 24, 2013 Hi, Roly, You should have received a tester with your air-brush to check the consistency of the paint. Like Kevin said, about the thickness of milk. In the tester, you want the paint to drip out of the nozzle rather than running through it. Good luck and God Bless! Spirithorse Thanks but no tester with this kit that's the UK for ya . It's what people use to thin the paint I was looking for as the named brands are expensive and it appears most people only use water only. Thanks for info and God Bless Roly Quote
Phantom Scroller Posted December 24, 2013 Author Report Posted December 24, 2013 Hi Roly I only use water based acrylic paint and distilled water for thinning. I usually run distilled water through the air brush at the start and end. Distilled water no chloride good idea Ron thanks. Roly Quote
amazingkevin Posted December 24, 2013 Report Posted December 24, 2013 hoo hoo i got lost counting the hardback books of airbrushing i have on the shelve.great library of info.i put all my airbrush stuff on craigs list and was offered pennies on the dollar for it all, Quote
Phantom Scroller Posted December 25, 2013 Author Report Posted December 25, 2013 hoo hoo i got lost counting the hardback books of airbrushing i have on the shelve.great library of info.i put all my airbrush stuff on craigs list and was offered pennies on the dollar for it all, Well you tell Craig to bring them back. Roly Quote
amazingkevin Posted December 25, 2013 Report Posted December 25, 2013 Mr.ROLY sir,These are my pride and joy,But I would trade the whole kit and kaboodlefor a nice scroll saw of choice,And what a set up it is too.Are blades included? Phantom Scroller 1 Quote
