This piece was made from Poplar. The design was based on the existing furniture she had in the room. The front legs were cut on the band saw using the compound cutting technique. The back legs were turned on the Legacy ornamental mill. The top was cut on the RBI scroll saw. The drawer front was made using a combination of the RBI scroll saw and the inverted pin router. To make the drawer front I drew the design on a piece of 1/4" plywood and cut it out on the scroll saw, attached it to a piece of 3/4" plywood and cut a 3/8" deep groove the shape of the design into the 3/4" plywood. Removed the 1/4" template and threw it away. Now I have a cutting template for the pin router. Next I took a 10" wide Poplar board and attached the cutting template to the board and cut out my piece. I repeated this process until I had enough pieces to stack together to make the drawer front. I glued two pieces together then added 3 or 4 pin nails to hold it in place. I added another on top of that and repeated the process until the drawer was done. I didn't use pin nails on the last pieces. Then I put it all in clamps, I sanded it with 80 grit in clamps while the glue was wet and dripping so the sawdust would fill in any gaps. The painting was done in 4 steps. Black primer, then I painted certain areas with a red, then I painted it all black. When the black dried I took 0000 steel wool and rubbed off the black until the red showed through. Then I sprayed a pre cat lacquer to seal it all together.
Elegant and stylish,Took my breath away seeing such a piece as this! You don't fool around.Your maid would be sick for a year if she looked at the clean up job in my yard shop,lol.This looks like presidential furniture for the White House.Keep them coming!
Great work, Garcia!
Every project you show makes me wonder how such great work can be accomplished.
As Browder said, Ihave some serious woodworking envy! LOL
Thanks for sharing and thanks for the explaination of the process.
God Bless! Spirithorse
  • 2 weeks later...
