oldhudson Posted March 10, 2015 Report Posted March 10, 2015 (edited) I’m a big fan of the Dowelmax, doweling jig. There are lots doweling jigs on the market but IMHO it is the best of the lot. I use it most because I find it much easier than making traditional mortise and tenon joints. However, that’s not what this post is about. I used it this weekend to re-enforce the miter joints on a picture frame. Miters on picture frames are inherently weak joints. Just those small end grain areas of glue. Using splines to re-enforce miters is a great method and with contrasting wood very attractive. They are not very difficult if you have a decent table saw. But the frame I was working on had a profile, with a concave surface, on the outer edge. While this doesn’t prevent using a spline it makes it more difficult. I could and have stapled the back of the frame. That’s fast and cheap but it’s not a very professional looking project. And there is the biscuit joint. I have a nice biscuit joiner but for some reason it doesn’t get used in my shop very often. So I don’t know how difficult it would be to set up to re-enforce mitered corners. So on to the Dowelmax. In making mortise and tenon joints I use a 3/8†dowel but for the frame I need a ¼â€. So I changed the drilling sleeves and set up a test. Then moved to the project and drilled all 8 holes. The whole process took about 15 minutes. It's a great way to re-enforce miter joints. (For the record I am not now nor have I ever been employed by Dowelmax and have no connection direct or indirectly to the company or it's staff.) P.S. If you notice the wrinkled shiny surface on the last pic - I put Saran Wrap over the oil painting to protect it while it's in the shop. I kindof a klutz and afraid I'll destroy the painting. Edited March 10, 2015 by oldhudson amazingkevin 1 Quote
Scrolling Steve Posted March 10, 2015 Report Posted March 10, 2015 Thanks for sharing!.....That has got to be a strong union Quote
Kepy Posted March 10, 2015 Report Posted March 10, 2015 I have used my biscuit joiner very successfully on picture frames. Quote
Dan Posted March 10, 2015 Report Posted March 10, 2015 Nice frame. I don't have tools for re-enforcing miter joints. I have been pretty lucky with just glue and clamping. I have several hanging in the house that were made over 10 years ago. I figure if they haven't given up the ghost yet they should hang in there for several more years. Quote
amazingkevin Posted March 10, 2015 Report Posted March 10, 2015 I'm always will to learn new tricks.I hate frames as I'm terrible on making boxes or anything square.This looks fool proof enough .Now i wish i hadn't let my biscuit machine go which i never knew how to use .But now the dowel sounds just like the ticket for fast and strong .Thanks! Quote
jamminjack Posted March 10, 2015 Report Posted March 10, 2015 Berry I am very pleased to see your craftsmanship goes far beyond scroll sawing. It is a pleasure to see someone going the extra mile to fix something as mere as a miter joint, taking the time and expertise to do such a top notch job. My hat is off to you sir....That is the sign of a true craftsman.... "YA Done good boy" Quote
oldhudson Posted March 10, 2015 Author Report Posted March 10, 2015 Nice frame. I don't have tools for re-enforcing miter joints. I have been pretty lucky with just glue and clamping. I have several hanging in the house that were made over 10 years ago. I figure if they haven't given up the ghost yet they should hang in there for several more years. Overall I've had good luck too but on this 21" x 24" frame with glass as well as the print it gave out some years ago. Of course the glass shattered and since then I've re-enforced frames with glass. I've been ask to make a frame for a large living room mirror so I'm working on ideas. The frame in question will have 2 or 3 dowels at each corner. Quote
Phantom Scroller Posted March 10, 2015 Report Posted March 10, 2015 Berry there are so many ways to make frames biscuits,v nails,glue and loads more but a dowel certainly makes for a good joint, always great to have the right kit. I like the framing did you buy it in lengths? Roly Quote
oldhudson Posted March 10, 2015 Author Report Posted March 10, 2015 Berry there are so many ways to make frames biscuits,v nails,glue and loads more but a dowel certainly makes for a good joint, always great to have the right kit. I like the framing did you buy it in lengths? Roly I picked up a couple of 8' lengths or this "architectural molding" at a local big box store (Menards). It was pretty cheap too, although I don't remember the cost, something like $6 or $7 per section. It's quite soft. I think it's a wood composite of some sort. It even came with a rabbit. Phantom Scroller 1 Quote
Dan Posted March 11, 2015 Report Posted March 11, 2015 . It even came with a rabbit. Must be Easter molding. He he. (A little seasonal humor.) Phantom Scroller 1 Quote
