Question for you Inkscape users.  When you join 2 or more objects as one (I think it is called welding), can it be un-joined or un-welded?  I have been skimming thru Travis's videos but did not find this, if it is in one of his lessons maybe someone could mention which lesson.
TIA, Bob
Edited by tvman44
Hi Bob it's Bob here! lol, If you've grouped two objects together to ungroup them look at the top bar,
Hover over the icons and it tell's you what they do!.....Just to the left of the letter "T" at the top is
were you will see what you need to click on o.k.
P.S. If you have two path's that you have put together it is called a "union"....To break them apart
you hold Ctrl+Shift+K o.k.
Bob  ;)
It depends on how the shapes are put together.  If you are doing a Union (welding) to create a unique shape, they cannot be separated again because it creates a new shape.  If you have a hole in a shape, you can break that apart (Ctrl+Shift+K), which separates the two shapes that make up that shape.  But that's only for shapes that have holes in them.
