Lilly Smith Posted October 5, 2015 Report Posted October 5, 2015 Can anyone tell me what is the best way to save my inkscape pattern? I want to ultimately have all of the patterns as JPEG, just because JPEG's can be worked on in any graphic program, However, Inkscape does not allow JPEG. How can I get the pattern ultimately to a JPEG file?\ Quote
sullyscroller Posted October 5, 2015 Report Posted October 5, 2015 If you also have Gimp save in Inkscape as PNG then open with Gimp and save as jpeg. sully Lilly Smith 1 Quote
Travis Posted October 5, 2015 Report Posted October 5, 2015 Sully's correct. Inkscape does not support JPG natievly. You'll need another program to convert a PNG to JPG. A lot of people use GIMP because it's free. But any photo program will be able to do that. You can also use an online converter like Image Converter. Quote
Lilly Smith Posted October 6, 2015 Author Report Posted October 6, 2015 Thanks a lot. I do use GIMP so it is easy to do this. I really appreciate it. Quote
Robert H. Bigart Posted October 10, 2015 Report Posted October 10, 2015 Try "Irfanveiw". Phantom Scroller 1 Quote
Lilly Smith Posted October 12, 2015 Author Report Posted October 12, 2015 I'm not even sure what you mean by that, but thank you for trying to help. I just used Photoshop Elements and saved it as a png and then used GIMP to save that as a JPEG. This is what I do with PDF files also. Not the quickest route, but, It works! Quote
amazingkevin Posted October 13, 2015 Report Posted October 13, 2015 I'll down load it later,thanks Try "Irfanveiw". Quote
Robert H. Bigart Posted October 13, 2015 Report Posted October 13, 2015 First take a picture with Print Screen the load "IrfanVeiw" and then hit Ctrl v do what you want to do with it then save. You can save it in over 20 difference formats. Quote
Robert H. Bigart Posted October 13, 2015 Report Posted October 13, 2015 I am sorry I spelled it wrong should be "IrfanView" . My bad Quote
Robert H. Bigart Posted October 13, 2015 Report Posted October 13, 2015 "IrfanView" saves in the following. BMP - Windows Bitmap ECW - Enhanced Compress Wavelet EMF - Enhanced Windows Metafile FSH - EA Sports GIF - Compuserve GIF ICO - Windows Icon JLS - JLS Format JP2 - JP2 Format JPG - JPG/JPEG Format JNG - JNG Format JMP - JPM Format PCX - Zsoft Paintbrush PBM - Portable Bitmap PDF - Portable Format PGM - Portable Graymap PNG - Portable Network Graphics PPM - Portable Pixelmap RAW - RAW Image Data TGA - Truevision Targa TIF - Tagged Image File Format WEBP - Weppy File Format Quote
Phantom Scroller Posted October 13, 2015 Report Posted October 13, 2015 (edited) I'm not even sure what you mean by that, but thank you for trying to help. I just used Photoshop Elements and saved it as a png and then used GIMP to save that as a JPEG. This is what I do with PDF files also. Not the quickest route, but, It works! Lilly export image in Inkscape and open in photoshop it will convert a png as a jpeg just drop the menu when saving and select jpeg Edited October 13, 2015 by Phantom Scroller Quote
Robert H. Bigart Posted October 14, 2015 Report Posted October 14, 2015 "IrfanView" is also FREE/ Quote
