breadstick Posted April 14, 2016 Report Posted April 14, 2016 I'm making a plaque for a friend and I'm gluing half a plastic football helmet to the wood. I cut a groove for it to fit into, but I'm worried about the glue. I have Titebond III and Gorilla 2-part epoxy. Is one of these better than the other? Quote
Bill WIlson Posted April 14, 2016 Report Posted April 14, 2016 I would probably use either a CA glue or an epoxy, or even a combination. I would definitely not use Titebond III. I think Titebond is best suited for wood to wood applications. Quote
oldhudson Posted April 14, 2016 Report Posted April 14, 2016 Epoxy or CA with an accelerator. Scrolling Steve 1 Quote
amazingkevin Posted April 14, 2016 Report Posted April 14, 2016 I remember a two part epoxie in can "A" and can "B" ,can't remember the name of it but the display had all kinds of things glued to a coke bottle,Ah it just came to me PC 11,thick as peanut butter and hard to find anymore would be a good choice for you! Quote
grosa Posted April 15, 2016 Report Posted April 15, 2016 (edited) J-B WELD 8265-S Epoxy Adhesive, Cold Weld, works great for that type of application. You do need to rough up the surface for a good mechanical bond. Edited April 15, 2016 by grosa Quote
edward Posted April 16, 2016 Report Posted April 16, 2016 I did one last year of a wedding heart and used welbond glue, dries clear, and make sure you clamp the pieces together, never had a problem. edward Quote
