Dave Monk Posted June 5, 2016 Report Posted June 5, 2016 (edited) I've been putting together some text and clip art in inkscape and it is not printing everything on the page. I would appreciate any help. I am frustrated. thanks, dave After hours of trial and error I found a way to work around the issue. Edited June 6, 2016 by Dave Monk Quote
Travis Posted June 7, 2016 Report Posted June 7, 2016 Can you post your inkscape file? Then we can take a closer look. Dave Monk 1 Quote
Dave Monk Posted June 9, 2016 Author Report Posted June 9, 2016 (edited) I put my text between the two images,,, the images would print but not my text. What I ended up doing was put a box behind it and colored it white and then it would print my text. Thanks for what you do Travis. dave Edited June 9, 2016 by Dave Monk Quote
Dave Monk Posted June 9, 2016 Author Report Posted June 9, 2016 (edited) I put my text between the two images,,, the images would print but not my text. What I ended up doing was put a box behind it and colored it white and then it would pint my text. Thanks for what you do Travis. dave Cubs and cards house divided.svg Edited June 9, 2016 by Dave Monk Quote
Travis Posted June 9, 2016 Report Posted June 9, 2016 Huh. STrange. I took a look at the pattern. Everything looks like it's in place. I removed that white box you mentioned and tried printing and it seemed to print just fine. I'm wondering if your printer is acting up? Have you tried printing to a PDF (i use Primo PDF)? It sounds like you found a solution. It's just a strange quirk that I'm not seeing the cause of. Dave Monk 1 Quote
Dave Monk Posted June 9, 2016 Author Report Posted June 9, 2016 I copied and pasted it in Word and part of the cubs artwork is gone. Something crazy going on, Don't worry I got it to work that's all that matters. Thanks, dave Quote
