NC Scroller Posted August 3, 2016 Report Posted August 3, 2016 I am attempting to make my very first intersecting word art pattern using Inkscape. The issue is when I go to print it it is so large that I only get like two letters. I want to print on legal paper. How do I resize to entire design and not loose my alignment? Quote
WayneMahler Posted August 3, 2016 Report Posted August 3, 2016 I normally draw mine up in landscape. I set the page size to 8.5 x 11 and the make the pattern. If you need a larger view of the pattern hold down control key and then scroll the mouse wheel to enlarge or decrease the viewing/working area. Once I like it, I save it as a pdf file. Close Inkscape and open the pdf file. When you go to print, select poster then set the percentage. Then select print and joint the pages together once printed. I hope this makes sense, I am so used to doing it this way and it works very well for me. fastfreddy and NC Scroller 2 Quote
Jim Finn Posted August 3, 2016 Report Posted August 3, 2016 On my computer I print everything in "Paint" that comes with the operating system. I just use and re-use the "resize" function there, read the dimensions in inches on the bottom of the screen until I get the size I need. NC Scroller 1 Quote
amazingkevin Posted August 3, 2016 Report Posted August 3, 2016 Boy someday i hope all this clicks in my head so i too could be one of the pattern guys ! thanks I am attempting to make my very first intersecting word art pattern using Inkscape. The issue is when I go to print it it is so large that I only get like two letters. I want to print on legal paper. How do I resize to entire design and not loose my alignment? I normally draw mine up in landscape. I set the page size to 8.5 x 11 and the make the pattern. If you need a larger view of the pattern hold down control key and then scroll the mouse wheel to enlarge or decrease the viewing/working area. Once I like it, I save it as a pdf file. Close Inkscape and open the pdf file. When you go to print, select poster then set the percentage. Then select print and joint the pages together once printed. I hope this makes sense, I am so used to doing it this way and it works very well for me. On my computer I print everything in "Paint" that comes with the operating system. I just use and re-use the "resize" function there, read the dimensions in inches on the bottom of the screen until I get the size I need. Quote
Iguanadon Posted August 3, 2016 Report Posted August 3, 2016 Scott, I'm not fluent with Inkscape, so I may be off base here, but take a look at trying this... Go to PRINT and then click on PREFERENCES, you can select your paper size, etc, then you should see this tab... http://screencast.com/t/C6q00PyA FIT TO PAGE in theory should work... Good luck. NC Scroller and Fab4 2 Quote
fastfreddy Posted August 3, 2016 Report Posted August 3, 2016 I normally draw mine up in landscape. I set the page size to 8.5 x 11 and the make the pattern. If you need a larger view of the pattern hold down control key and then scroll the mouse wheel to enlarge or decrease the viewing/working area. Once I like it, I save it as a pdf file. Close Inkscape and open the pdf file. When you go to print, select poster then set the percentage. Then select print and joint the pages together once printed. I hope this makes sense, I am so used to doing it this way and it works very well for me. I was also wondering about how to do that, thanks for that information, going down on notebook tips Quote
Travis Posted August 4, 2016 Report Posted August 4, 2016 I think the first step is to make sure you designed your pattern the size you want to eventually cut it. I wasn't clear if that is the case or not. If not: Select your whole design and Group it (ctrl+g). Select your group. Go to the top and click the Lock icon. This will lock your aspect ratio so you don't distort your image when resizing. The pulldown on the right is probably defaulted to "px". Choose In for inches (or whatever scale you want) Then for width, type in how wide you want to make it. As far as getting it on 1 page, I suppose if it's small enough to fit on 1 page, you'll be fine. However, my experience, especially with this type of pattern, you'll want it fairly large. Here's a tutorial on how I print oversized patterns. Hopefully that will help. Fab4 and NC Scroller 2 Quote
NC Scroller Posted August 5, 2016 Author Report Posted August 5, 2016 I think the first step is to make sure you designed your pattern the size you want to eventually cut it. I wasn't clear if that is the case or not. If not: Select your whole design and Group it (ctrl+g). Select your group. Go to the top and click the Lock icon. This will lock your aspect ratio so you don't distort your image when resizing. The pulldown on the right is probably defaulted to "px". Choose In for inches (or whatever scale you want) Then for width, type in how wide you want to make it. size.JPG As far as getting it on 1 page, I suppose if it's small enough to fit on 1 page, you'll be fine. However, my experience, especially with this type of pattern, you'll want it fairly large. Here's a tutorial on how I print oversized patterns. Hopefully that will help. Thanks Travis. I just started my design without thought to final size. What I designed was roughly 4X what the final should have been. Kinda tough cutting out a 6' piece of wood art. Another variable lesson learned. Quote
Debi Shipman Posted August 7, 2016 Report Posted August 7, 2016 I don't mean to jump in, but what size do the ones in the pattern library print out to? I have to do my printing at the library and usually I just click "actual" on the size. If it starts spitting out a dozen pages, I may get kicked out. lol Quote
Phantom Scroller Posted August 8, 2016 Report Posted August 8, 2016 Save it as a PDF and resize to print in Adobe Acrobat. Roly Debi Shipman 1 Quote
Debi Shipman Posted August 9, 2016 Report Posted August 9, 2016 Save it as a PDF and resize to print in Adobe Acrobat. Roly Thanks, Roly. I tried printing it as is and got the middle couple of letters. Quote
djhwoodwerks Posted August 13, 2016 Report Posted August 13, 2016 Make sure before you start designing your pattern, you resize the page to what you want. If you're printing on legal paper, 8.5 x 14, select that for your page size and then design accordingly. Debi Shipman 1 Quote
