Not sure if this is the right place to ask, but here goes.  I have a belt sander that has an 8" sanding disc.  It's nearly impossible to find that size locally, but I can find 6 inch.  Would there really be any harm in using the 6" or 7" discs on this machine?
Hi Nathan, I would use full sheets and use the disc as a template to make your own. The Standard size sheet is usually 9 inches X 11 inches. (in the UK anyway) Hope this helps.
Rob Roy.
