www.sloanswoodshop.com/clock%20inserts.htm
www.bearwood.com/clock-inserts-fit-ups-2-3-4-inches.html
http://www.woodenteddybearonline.com/x/home.php?cat=20
www.woodworkingparts.com/2-3-4-clock-fit-up/
I use to promote Wildwood Designs but have stopped. You can take your chances there. I will say this all these companies buy from the same dealerships. If possible I try to use the inserts with the clips. They are becoming harder to find and most use the rubber gaskets. They dry out and at times are hard to get inserted in the hole properly. The last time I ordered from Sloans they still had them but that was over 2 years ago and I have been somewhat out of the loop. Stay away from ordering from Steebar. Bad things happen there. Now they do make various grades. Economy, standard ( all have plastic bezels) and Premium if you can still find them. They have a glass bezel and better motor but are expensive. I use those on the special projects. Good luck.
Edited by JTTHECLOCKMAN
Can anyone direct me to the best place purhase clock inserts online. I'm mainly looking for 2 3/4 clock inserts and 1 7/16 clock inserts.
Thanks.
Ciao
Bronx
tons of places if you google it
Klockit.com is great.
i like their stock
I buy mine from Sloans and like the quality, and are reasonable, go to there website.  edward
i'll have to look at there's
humm good to know
