kmmcrafts Posted July 25, 2017 Report Posted July 25, 2017 (edited) I have two images that I'd like to merge together.. in other words I have two patterns both round in shape.. one being a larger than the other.. I need to insert the smaller one into the center of the larger one.. how ever the complete image is square so when I try to merge the two.. the smaller one is covering up a portion of the larger one because of the square shape of the image.. Hope I am making sense. LOL I am guessing I need to somehow.. cut out the smaller one by sort of cropping it.. however cropping programs always crop square or rectangle shape and I need round, LOL.. Cut and paste? How does one do this? I have both inkscape and gimp 2 on .. rather know on inkscape.. but I will take whatever info I can get from either program.. beggars can't be choosers LOL Thanks in advance for any help Kevin Edited July 25, 2017 by kmmcrafts Quote
TheWoodArtist Posted July 25, 2017 Report Posted July 25, 2017 In Gimp at the top of the tool box next to the rectangle crop. Use that on the one you are wanting round and then copy and then create from clipboard and take out the checker board that is on the corners and then you'll have your round that you want kmmcrafts 1 Quote
kmmcrafts Posted July 26, 2017 Author Report Posted July 26, 2017 10 hours ago, TheWoodArtist said: In Gimp at the top of the tool box next to the rectangle crop. Use that on the one you are wanting round and then copy and then create from clipboard and take out the checker board that is on the corners and then you'll have your round that you want Thank you, that worked great. Now I just got to figure out how to put an x in the center so I can center the clock in the middle.. Quote
amazingkevin Posted July 26, 2017 Report Posted July 26, 2017 15 hours ago, kmmcrafts said: I have two images that I'd like to merge together.. in other words I have two patterns both round in shape.. one being a larger than the other.. I need to insert the smaller one into the center of the larger one.. how ever the complete image is square so when I try to merge the two.. the smaller one is covering up a portion of the larger one because of the square shape of the image.. Hope I am making sense. LOL I am guessing I need to somehow.. cut out the smaller one by sort of cropping it.. however cropping programs always crop square or rectangle shape and I need round, LOL.. Cut and paste? How does one do this? I have both inkscape and gimp 2 on .. rather know on inkscape.. but I will take whatever info I can get from either program.. beggars can't be choosers LOL Thanks in advance for any help Kevin kevin to kevin good luck with you task Quote
bobscroll Posted July 27, 2017 Report Posted July 27, 2017 Hi Kevin This might help explain how to do your cross in the middle using the Inkscape program, Bob Phantom Scroller and kmmcrafts 2 Quote
merlin Posted July 28, 2017 Report Posted July 28, 2017 So that's how it's done Bob.....Thanks for that info......................... bobscroll 1 Quote
kmmcrafts Posted July 30, 2017 Author Report Posted July 30, 2017 Wow! thanks for the info.. I can't wait to give this a try and make another clock pattern.. Kevin bobscroll 1 Quote
