Amazon.com advertises both the window film and the faux stained glass panels.
Some craft stores like Hobby Lobby sell kits of some type of acrylic liquid that you can mix to your own
satisfaction and then I think it has to be baked to harden.
www.woodenteddybear.com and www.scrolleronline.com both sell the acrylic sheets but, they are only one color.
God Bless! Spirithorse
Roly, you could make your own colored panels, and it would probably be cheaper then buying the precolored sheets. All you need to use, is clear plexiglas. I don't know what you're attempting to make, but I've seen clear plexi that was colored by a friend. You can make it any color you want, lots more selection then in buying the precolored sheets. And lots less waste, because you can color it once it's cut out. All you use is the glass paint that comes in bottles, I found out about the paint from a friend. I have never used it myself, but I wouldn't hesitate to now that I've seen the outcome he used to get. I'd give you his e-mail address, but he passed away last year so there'd be no sense. But the paint should be easy enough to find, I'll look for it when I'm done on here. It isn't a solid color paint, it looks like stained glass when applied.
Len
