Hi all
My old psp program won't run on windows 7. I am trying to use paint.net to resize patterns. Are there any simple instructions that I can print out and follow. I don't understand this aspect ratio thing and when I go to print in windows 7 I get this stupid window that wants to know what size photos I want. I just want to print out the resized pattern in a simple way.
Thanks
Bill
Here ya go Bill: Tutorials
I use paint.net.
At the bottom of the window you should see an "options" link -it's pretty small. From there you can set your printer preferences.
When I print I choose full - don't forget to uncheck the "Fit picture to frame" at the bottom
hope that helps somewhat
Also - forgot to mention:
"In Windows 7, Paint.NET does not have a way to print "actual size".
However, if you save it, then read it into MS Paint there is a page setup that will let you set the scaling to 100%. If you then print, it will print it actual size."
Or you can make the image into a pdf and print it actual size that way as well
I use the ms-paint method myself - it's easier and faster
Edited by new2woodwrk
