1 hour ago, Clayton717 said:
here is the latest and last bowl for a while. This one is segmented together using a lot of different pieces for each ring and several different species of wood. Now back to some intarsia I've been putting off.
Amazingly tight seams with all the different woods,Only you could have done that .Really makes you admire the bowl design while eating from it.Another fabulous work of art by you!!!!!!thanks for sharing!!!!!!!!!!!!!!
9 hours ago, Lucky2 said:
Clayton, that is one crazy looking segmented bowl blank, did you glue it up yourself? It turned out to be a nice looking bowl, how large is the bowl?
Len
Thanks Len. Yes I glued this up myself.  At the widest point is is 8" diameter and 4" tall.
On 2/9/2018 at 9:51 AM, scrollerpete said:
The patience required to cut and glue all these pieces together was the hardest thing to do I think the cutting would be a breeze after. But than come the shaping/sanding this is a master piece that need to be display at a great location in your house.
Pete, you do realize that this bowl was turned on a lathe, not sawn on a scroll saw, right?
Len
  • 3 weeks later...
