I'm currently working on "Little Buddy" by Bruce Worthington.  My question is should I cut out all of the pieces before shaping and sanding or when I get one section, in this case his overalls, sand and shape that before continuing with other areas?
Chris
Chris
Myself too would cut everything first!Keep us posted on your progress!!!!!!!!!!!!!!
Thanks guys, that was my thinking too but I just needed to confirm that. This is to date the largest intarsia piece I've taken on.
So far I've only had to recut 2 pieces to get a good fit. Something I've learned so far is the width of the line makes a HUGE difference in fit....
Chris
Cut everything first, Than step back and look at the piece to see what would be closest to you if it was real life. Now raise & lower pieces accordingly. Than start shaping with the thinnest pieces and work towards the thicker pieces
