jbrowning Posted April 1, 2018 Report Posted April 1, 2018 Has anyone made a table and fence for a drill press to use with a sanding mop? Just trying to collect some of the dust while using the drill press and sanding mop. Quote
Dan Posted April 2, 2018 Report Posted April 2, 2018 I don't have a fence. I just hold the piece and sand away. As for dust collection, good question. My drill is the only tool with no dust collection. Quote
new2woodwrk Posted April 2, 2018 Report Posted April 2, 2018 I made a drill table and a home made fence as well but I don't use a sanding mop - at least not yet For dust collection, I currently have a pvc 'L" I hold to the drill piece. Here's the fence I made I also made these risers to help I will however, be making a "hold" for the dust hose over the next few weeks.using a large welding magnet from HF When it's done I'll post it but it will be awhile yet - can't find the pics of it, but I'll look again Quote
munzieb Posted April 2, 2018 Report Posted April 2, 2018 I have not built a fence (yet) for my drill press stand and cart. To remove cutting fuzz, I use the HF scotch brite balls in the drill press. I typically hold the piece in my hand and rotate in several directions to remove all the fuzz. If the piece is delicate, I will lay it on the bench and use a hand drill to clean it up. I have my shop vac standing by for when it's done and its all gone in a few seconds. Quote
RangerJay Posted April 2, 2018 Report Posted April 2, 2018 This carvers dust collector is a powerful fan that gets a lot of use in my shop - it's pricey but does a good job of sucking up fine sanding dust that would end up floating in the air - it does not pick up heavier sawdust that immediately settles. I don't use beside my drill press but do use it beside my scrollsaw and other tools including on my bench when sanding with the dremel tool or my other portable sanders - including my sanding mop when mounted on a cordless drill. Obviously the closer you have the fan to your sanding source the better it is. Jay Quote
amazingkevin Posted April 27, 2018 Report Posted April 27, 2018 I Mopped in front of the ac intake with a pleated paper filter and no dust was in the house. Quote
Woodmaster1 Posted April 28, 2018 Report Posted April 28, 2018 I made a table but dust collection. I think I will add a big gulp or the smaller version soon. Quote
