Uncle Ricky Posted April 19, 2018 Report Posted April 19, 2018 How do I change my display name from Bulldog557 to Uncle Ricky, hope one of you can help me with this. thanks in advance. Quote
meflick Posted April 19, 2018 Report Posted April 19, 2018 You can try to draw someone's attention to a thread by adding a @ in front of their username (with no space between) like this @Travis or @Clayton717 Another option would be to send them a private message via the forums. If you are on a computer, in the top left of the screen, you should see your username and then to the left of that an envelope and a bell which gives you notifications of when you have had a private message sent to you (the envelope) or when someone quotes you in a post or reacts to a post you made (the bell). If you click on the envelope, it will take you to your private message area and there is a green "compose new" button over near the top left, click on that and then start entering the username(s) for the person(s) you want to send a private message to. As you start typing, it will give you suggestions as to usernames - when that occurs, you can scroll through and select the one you want. You separate multiple users by adding a comma after their user name. This ensures that they get and see your message probably most quickly. Otherwise, you are waiting for them to see the notification that they have been tagged in the message/thread on the forum if you tag them. Without doing either, it is possible that they miss your message I am afraid. Hopefully one of them can provide you with an answer soon as to whether or not it can be done. OCtoolguy 1 Quote
Travis Posted April 19, 2018 Report Posted April 19, 2018 @Uncle Ricky (formerly known as Bulldog557), I changed your display name and sent you a PM. OCtoolguy, meflick, new2woodwrk and 1 other 3 1 Quote
