jerry1939 Posted January 22, 2019 Report Posted January 22, 2019 We have Windows 10 Edge. Yesterday the made "big" changes. HA. I was working on a time consuming pattern in Inkscape. That disappeared. Oh the joy. jerry Phantom Scroller, meflick, amazingkevin and 2 others 1 4 Quote
jollyred Posted January 23, 2019 Report Posted January 23, 2019 I feel your pain. I do not store my patterns on my computer, I use a dedicated flash drive and work on them directly from the flash drive. That way, if anything happens to the hard drive (such as an update), I will not lose my patterns. I have hardly anything I want to keep stored on the computer. I don't use the "cloud", but that would be another way to keep them stored. Tom jerry1939 and don watson 2 Quote
Phantom Scroller Posted January 23, 2019 Report Posted January 23, 2019 Jerry things don't just disappear it's usually down to operator error haa haa my wife says to me it's all gone wrong. I say what did you do, answer nothing. So I check the back button and find she's hit various buttons numerous times and the poor computer says what the...... Roly amazingkevin 1 Quote
spirithorse Posted January 24, 2019 Report Posted January 24, 2019 Oh, Jerry! I feel your pain! I hope you can find the file some-where, some-how, and soon. God Bless! Spirithorse Quote
RabidAlien Posted February 1, 2019 Report Posted February 1, 2019 Couple of articles to check to recover files: http://wiki.inkscape.org/wiki/index.php/Emergency_save https://www.easeus.com/file-recovery/recover-lost-unsaved-inkscape-files.html Quote
jerry1939 Posted February 2, 2019 Author Report Posted February 2, 2019 7 hours ago, RabidAlien said: Couple of articles to check to recover files: http://wiki.inkscape.org/wiki/index.php/Emergency_save https://www.easeus.com/file-recovery/recover-lost-unsaved-inkscape-files.html Thank You for the research you did Sir !!! I tried your 1st suggestion & got nowhere. Downloaded the 2nd one & couldn't find my pattern, so I uninstalled it. By dumb luck, I had printed what I had completed to show to the Sweet Wife. We found that. Something I never had to try was when you import into inkscape, will an imported picture print. IT DOES. Now I can import what I had completed & continue from where I left off. Thanks again Friend. jerry RabidAlien 1 Quote
RabidAlien Posted February 2, 2019 Report Posted February 2, 2019 4 minutes ago, jerry1939 said: Thank You for the research you did Sir !!! I tried your 1st suggestion & got nowhere. Downloaded the 2nd one & couldn't find my pattern, so I uninstalled it. By dumb luck, I had printed what I had completed to show to the Sweet Wife. We found that. Something I never had to try was when you import into inkscape, will an imported picture print. IT DOES. Now I can import what I had completed & continue from where I left off. Thanks again Friend. jerry Another tip is to follow the example set by the Good Lord.....save, and save often. Quote
teachnlearn Posted February 21, 2019 Report Posted February 21, 2019 Possible that you had the save file on a different folder. If you remember the file name you can search to see if its somewhere else. If you don't have a search there is free search software called "Search Everything" Helps to locate any file. https://www.voidtools.com/ Quote
