Vector01 Posted December 4, 2010 Report Posted December 4, 2010 Recently received some hardwood planks from one of the maintenance crew where I live. He is also a Lt. on our local Fire Department. There was no charge for the wood He asked if I could cut him one of the fire trucks in his department. I said "No problem." The pattern for the truck is almost done. I would like to go a bit extra and make him a nice plaque based on the departments emblem/patch. The problem is I'm not sure how to go about it My two ideas are 1) do a segmented piece with the butting edges rounded over or 2) Do a bevel cut so that the smaller pieces are raised above the outer ring (red oak). Unfortunately my intrasia a segmented skills are poorly lacking. I'm looking for a procedure that will fit tightly and look good. I will be working with 3/4" red oak, maple and cherry. I would like to incorporate all three woods in the design. Any suggestions will be greatly appreciated. I've included a basic picture of the emblem/patch. Thanks! Quote
Oges Posted December 5, 2010 Report Posted December 5, 2010 Perhaps do the emblem in a segementation style and then stain the pieces in the colours that you want? Quote
Clayton717 Posted December 5, 2010 Report Posted December 5, 2010 If you want to use all 3 types. I would cut out the red oak get the shapes cutout of it and sanded, then use that as your pattern for the inside pieces. just lay over your next type of wood and trace it. or trace it on paper and apply to wood. Quote
Vector01 Posted December 5, 2010 Author Report Posted December 5, 2010 Great ideas...I figured I couldn't stack cut the pieces. But using the inner pieces as templates for the other woods sounds doable. That way my entry holes for the inner pieces won't be as critical since the cutouts will only be templates. Quote
amazingkevin Posted November 10, 2012 Report Posted November 10, 2012 This is going to turn out nice two heads are better than one! Quote
