Somehow, and darned if I know how, inkscape now opens with "snap to" set to on.  I know how to turn it off.
What I can not find in preferences is how to set the default to off, anyone know?
Hi Jim
Does this help at all
Steps
  1. Go to File >> Document Properties and click on the Snap tab.
  2. Select 'Snap only when closer than:'. If it is already selected, leave it selected.
  3. Once you have checked it, close the Document Properties.
  4. Go to File >> Inkscape preferences and then locate the Snapping option. ...
  5. Use your snapping tool in Inkscape.
Fab4
11 minutes ago, Fab4 said:
Hi Jim
Steps
Fab4
No joy, all my settings were as you mentioned.
But I did fix it.  I went to C:\Program Files\Inkscape\share\templates
and right clicked on the default.svg file and opened with inkscape
turned off snap to
then file>save and it told me it could not save it, so I saved it on the desktop and closed inkscape
open win explorer, go to the templates folder renamed the default.svg file to default-old.svg and then moved the desktop defualt.svg file to the folder
when I reopened inscape, snap to was disabled - yeah!
