Goat Posted December 16, 2019 Report Posted December 16, 2019 Hi all, I have a project I need to get finished and shipped out to arrive for Christmas. I used oil based spray poly. My project is Pine, Wenge and Polar. The first coat went on great. Can says dry to the touch in 4 hours, hard in 12. The Pine and Polar took about 6 hours to dry, the Wenge however is still taky after 27 hours. I have a second coat on the Pine and Polar and that is almost dry already. The 1 coat on the Wenge looks really good but the grain is pretty open so not sure if the coverage is 100%. I figure I could probably get 3 coats on the Pine and Polar, but I don't think I would have time to glue the project if I put another coat on the Wenge. Do you think 1 coat will be good enough to keep the moisture out? Will 2 days be enough time for the glue to dry? Thanks Quote
don in brooklin on Posted December 16, 2019 Report Posted December 16, 2019 I find glue dries in about an hour but it takes over night any stress on it. You should be okay. 3 coats of poly on the pine and popular should be good. Wenge is tough to finish. There must be oils in the wood and so drying time is real long. I have used wenge as accent in cutting boards and it absorbs oil really different than all other hardwoods. If it looks good I would not want to mess with it. jollyred and GrampaJim 2 Quote
tgiro Posted December 17, 2019 Report Posted December 17, 2019 I always wipe Wenge with acetone or denatured alcohol before I coat it. Then I sometimes give it a coat of thinned oil before applying any other finish. let it dry overnight with the coat of oil before applying another finish. I think it has an oil in it that doesn't react well with some finishes. meflick and amazingkevin 2 Quote
amazingkevin Posted December 17, 2019 Report Posted December 17, 2019 very nice info, tips an tricks here!!! Quote
