I will definitely keep that in mind Denny.  One thing though, I  read the site looking for twist drill or drill bits, passed them by twice cause they said blades
High Speed Steel Twist Blades
These miniature drill bits are all that you need to drill blade entry holes for even the finest fretwork.
$10.15 per tube of 10 USD
47 minutes ago, Scrappile said:
Good catch, Jim.  Even when I found them, I did not realize it said blades instead of bits.  I just saw twist and thought bits.
Dad seems to have cursed me, all my life I heard (one of many of his expressions)
Semantic accuracy is a trait to be desired.
arggg
I use a lot of different bits for the small veining in my car clocks.. many of them have veining cuts for body lines.. I mostly use a #60.. but also use a #58.. The #60 is the smallest bit to use for a Pegas #3 MGT blade and the 58 bit for the #5  The #3 and #5's is about all I use..  If I need a wider kerf than the #3 offers but need a small hole the #60 bit works with a #5 FD-UR which is a wider kerf
Thanks Jim.  I must have had blades on my mind.
A #60 drill is ..o4o abd tge #58 is .042 that is only .002 difference on my drill chart I use a 3/64 dril which is which is .0469 not much difference on most patterns.
IKE
  • 3 weeks later...
