OzarkSawdust Posted January 10, 2020 Report Posted January 10, 2020 I thought I had this...but my "Birds of Paradise" font will not come up in Inkscape and I'm running short on time. I want to cut a sign from 1" Oak Last name "STARR" in New Times Roman First names "Jake & Barbara" in Birds of Paradise scalloped corners ( I need to do that on my sign as I think it looks more finished ) Like my sign in the picture...but names only...NO wedding date! It's for a next door neighbor back home and the guy that commissioned me didn't know the date. Thank you all so much! Quote
JimErn Posted January 10, 2020 Report Posted January 10, 2020 quick and dirty, check it for islands there might be one or two 4ozark.pdf frankorona, multitom and flarud 3 Quote
OzarkSawdust Posted January 11, 2020 Author Report Posted January 11, 2020 8 hours ago, JimErn said: quick and dirty, check it for islands there might be one or two 4ozark.pdf 76.45 kB · 0 downloads Thanks Jim!! Just what I was wanting. When I opened it in Inkscape it wouldn't let me resize it. Keeping the proportions the same, how wide can you make it and still print on 1 piece of paper? Quote
JimErn Posted January 11, 2020 Report Posted January 11, 2020 the sign is presently at 8.5 long Download the pdf, when you go to the print dialog there is a field to enter the size, 110% etc in inkscape, with the png or pdf on screen, hit control D, then move the copy away from the original, you should be able to resize the copy OzarkSawdust 1 Quote
Birchbark Posted January 11, 2020 Report Posted January 11, 2020 1 hour ago, JimErn said: the sign is presently at 8.5 long Download the pdf, when you go to the print dialog there is a field to enter the size, 110% etc in inkscape, with the png or pdf on screen, hit control D, then move the copy away from the original, you should be able to resize the copy When i looked at it, i get the canvas size of 7 5/8 x 11 3/8 at a dpi of 72. I wonder what that's about?? Russell Quote
JimErn Posted January 11, 2020 Report Posted January 11, 2020 58 minutes ago, Birchbark said: When i looked at it, i get the canvas size of 7 5/8 x 11 3/8 at a dpi of 72. I wonder what that's about?? Russell 72 is typically the screen resolution for display, in the pdf copy the page size is standard letter size, the black border in the pdf copy is my default page display at 8x10 - I forgot to turn it off before saving Quote
Birchbark Posted January 11, 2020 Report Posted January 11, 2020 1 hour ago, JimErn said: 72 is typically the screen resolution for display, in the pdf copy the page size is standard letter size, the black border in the pdf copy is my default page display at 8x10 - I forgot to turn it off before saving Yes Jim, I should've taken the time to look at the pdf. :) Gary i gave it a go as well. I made mine a .jpg file, in Landscape Orientation. If you print this, you'll have to print it that way. Russell multitom, OzarkSawdust, frankorona and 1 other 4 Quote
OzarkSawdust Posted January 12, 2020 Author Report Posted January 12, 2020 11 hours ago, Birchbark said: Yes Jim, I should've taken the time to look at the pdf. Gary i gave it a go as well. I made mine a .jpg file, in Landscape Orientation. If you print this, you'll have to print it that way. Russell Thanks Russell! Birchbark 1 Quote
OzarkSawdust Posted January 12, 2020 Author Report Posted January 12, 2020 15 hours ago, JimErn said: the sign is presently at 8.5 long Download the pdf, when you go to the print dialog there is a field to enter the size, 110% etc in inkscape, with the png or pdf on screen, hit control D, then move the copy away from the original, you should be able to resize the copy Thanks Jim!! I'll try it in the morning. Quote
