teachnlearn Posted February 26, 2020 Report Posted February 26, 2020 For those that have a bit of trouble reading the screen or want to magnify an image use your search on the lower left corner or right click the start and type 'magnify' in he search It should find a magnify setting. click it and turn on the magnify. Either a magnify window will popup or magnify will be on the lower task bar. I always click the minimize on it or if you close it, it disappears and you have to turn it on again. RJF crupiea 1 Quote
Foxfold Posted February 26, 2020 Report Posted February 26, 2020 I just did this and yes it did magnify, however it took me 10 mins to find out how to 'undo' it It was quite simple in the end, just pressed 'close' on the task bar. I am now 10yrs older Quote
Karl S Posted February 26, 2020 Report Posted February 26, 2020 On a Mac you just push Command+ and it will enlarge your type or Pictures Scrappile 1 Quote
teachnlearn Posted February 27, 2020 Author Report Posted February 27, 2020 On Windows its Ctrl plus sign to enlarge and Ctrl minus sign. The Magnify lets you super zoom and move around with the mouse. RJF If I wasn't clear, press the X on the window to close the Magnifier. RJF Quote
Be_O_Be Posted February 27, 2020 Report Posted February 27, 2020 I have a Dell with pen & touch support which allows you to magnify your screen like a smart phone, two fingers and expand. I don't use the touch screen option too often because of finger prints but to enlarge pictures or print its a breeze. In Windows 10 settings click "system" and then click "about" . The device specifications would have it listed " Pen and touch". Maybe easier to try using your screen like a smart phone. Hope this helps. Quote
