I'm trying to make a name sign. When I try to set smaller letters over large ones sometimes it doesn't stay where I put it! It moves a fraction.
I'm sure there is an alignment or something I can turn on and off...but don't know what it is or where to find it. Help please!
1 hour ago, JimErn said:
And looking at the pic Fab4 put up, very top right is an icon, that is snap to grid, be sure it is turned off
That "snap to grid" is probably what I'm looking for. I don't see it anywhere...is it called something else?
OK...I see a vertical line of icons on the right side of the screen.
1. Is it in there?
2. I don't have that...How do you open those icons?
Edited by OzarkSawdust
2 hours ago, Fab4 said:
Hi Gary
See if this helps you at all
Make sure you select both large and small letters and it will center it vertically and horizontally
Fab4
Thanks, I use those a lot. It was that "snap to grid" I couldn't find, or remember what it was called.
But your screen shot showed me what I didn't have so I went looking.
13 hours ago, OzarkSawdust said:
I found it !!!!
View
Show/Hide
Snap Controls Bar
Turn it off!
It appeared on top instead of the right side...but it works. Tough little bugger to find...when you don't use it.
Thanks Jim!
Odd that it was in a different place, I guess there are subtle changes from one version to another, glad you found and fixed the issue
