nrscroller Posted December 11, 2020 Report Posted December 11, 2020 HI all, Today I made a trip to a Rockler woodworking store with the thought in mind of buying the hanging dust collector for 269 dollars. In talking with one of the staff, he said he would not sell one to me because I am not collecting heavy table saw or planer chips etc, that I needed a dust extractor from my scroll saw and sanding stuff. He suggested a festool but I am not paying 700 bucks for that thing. He said for what I am doing I am best to use a shop vac for that stuff. Any suggestions, I have a wall mounted shop vac which I am using now and I just thought with my bad hearing and not wearing aids in the shop but just ear muffs I can still hear that shop vac screaming. It does a good job of keeping the scrollsaw dust down etc, and it is hooked up to a dust deputy, Thanks Bill amazingkevin and OCtoolguy 2 Quote
MrsN Posted December 11, 2020 Report Posted December 11, 2020 I had not really thought about it. I did some looking and found this article https://www.thesawguy.com/dust-collector-vs-shop-vac/ It sounds to me like a dust extractor can catch sawdust that goes in the air, while a dust collector collects the sawdust that collects on the floor. amazingkevin 1 Quote
Dan Posted December 11, 2020 Report Posted December 11, 2020 https://toolpowers.com/shop-vacs-vs-dust-extractors-vs-dust-collectors-what-is-the-difference/ https://vircet.com/dust-collector-vs-dust-extractors/ Quote
FrankEV Posted December 12, 2020 Report Posted December 12, 2020 Dust extractor clleans the air in a space, dust collector collects sawdust and small chips from a router, table saw. sander, scroll saw, etc. An extractor helps you breath clean air (like a dust mask does (for a lot less money) while a collector helps keep the shop clean better than a shop vac will. I just ordered a:SHOP FOX W1727 1 HP Dust Collector, ,Sold by: Amazon.com Services LLC for$268.86. With hoses, some other fitting and accesories, the total installation will be under $400. This Collector is for a small shop with up to 3 machines. HTH . amazingkevin 1 Quote
Zoot Fenster Posted December 18, 2020 Report Posted December 18, 2020 The Rockler guy steered you right. There are dust collectors (1-5Hp) that pull high air flow, but at low suction pressures. As the Rockler guy used the term, a dust extractor is a Shopvac or equivalent. They pull a low volume of air, but at high suction pressures. Dust collectors need 4-6" ducts and large openings (ie, table saws, vent hoods behind sanders, etc). Connecting a dust collector to a small connection will limit the air flow because there is not enough hole area to pull air through. A Shopvac has a greater suction pressure, so it pulls more air through the small machines like Ridgid sander and scroll saws. But connecting a Shopvac to a table saw results in poor performance because there is insufficient flow at the collection point. Clear as mud? Sorry about that. Quote
tomsteve Posted December 18, 2020 Report Posted December 18, 2020 (edited) dust extractor(vacuum)= speed of air dust collector=volume of air Edited December 18, 2020 by tomsteve Quote
